Old 12-12-2018, 09:52 PM   #1
NzBrakelathes's Avatar
Tourfella RX3 RX3S and RX4 accessories
TourFella bags for the side case $35 each or $70 a pair and postage to the USA $18.5 (1.75Kg) 2-4 weeks for delivery
They are made for the side causes and bought from TourFella for correct fitment, they have a couple extra pockets and open up like a clamb shell for easy packing, they slip into your cases easily (assuming you dont pack them to near bursting point)
Old 12-12-2018, 09:56 PM   #2
RX3 RX3S RX4 back cushions
The top cusion clips to the top of the box, the other either screwed thru the case or possible 3M tape $15 each plus postage
USA Epacket is only $0.01 per gram plus $2 a package so maybe $7.50 as a guide for shipping.
PM or email tako@nzbrakelathes.com
Old 12-12-2018, 10:00 PM   #3
3 cases strap set ( for 3 boxes)
Straps for the cases and photos with are not actual item but is how they function.
Photo of straps is the actual item and you get 3 of those as that photo shows what each box needs.
Old 12-12-2018, 10:08 PM   #4
TourFella top box button upgrade
Aluminium buttons to replace the worn or broken plastic top box locating buttons. $35 a set plus postage
Fitted directly and worked easily on my box & rack, 1 member bought a set and it was a little tight but I suspect it can relate to where the holes are made or drilled in the box or the rack (RX3 rack not made by Tourfella) so you might need to DIY the holes a little for smooth operation.
Old 12-12-2018, 10:11 PM   #5
over the top accessories!
something towards $100 plus shipping but I think OTT for the RX3
I haven't and wont test this - too expensive IMO
Old 12-12-2018, 11:28 PM   #6
sqwert   sqwert is offline
Just realized the side box straps will double as carry handles. SWEET!
Old 12-13-2018, 12:20 AM   #7
Yeah they do and also can strap down some light and bulky stuff.
Genuine Tourfella straps are double the price (for just 2) and I fail to see any benefit, this is a cost effective and good set with a tidy price.
Old 12-13-2018, 10:20 AM   #8
I was dubious on the value of the top straps. So far I've used only the top case set, but like them quite a bit. So easy to just put something under there and cinch it down. Also makes carrying that bulky thing so much easier. Haven't found a need for the side case straps yet, but I haven't done any trips either (just local errands and commuting).
So yeah...I recommend getting them. Good quality, too.
Old 12-13-2018, 06:55 PM   #9
Cheers for the feedback Sir
Old 12-14-2018, 10:13 AM   #10
Juanca   Juanca is offline
Juanca's Avatar
Waiting to get mines from NZ together with the TOP case pads, keep you all posted on comments.
Old 12-14-2018, 10:20 AM   #11
They’ve arrived long ago in NV - didn’t they advise you?
Old 12-14-2018, 12:33 PM   #12
Juanca's Avatar
Yes, I will be there in a aweek and then returning to Guatemala on the 1st, then put them on and try to give you comments.
Old 01-03-2019, 12:37 PM   #13
Juanca's Avatar
Update on my order from NZ, everything arrived in perfect condition and complete, thanks a lot mate.
The straps are of an excellent quality, just need help on how to attach them to the boxes, I have no idea how to tie them up.
Any help?
Old 01-03-2019, 02:28 PM   #14
It took a bit of fiddling around to see what they intended. I think I got it right. Works well anyway.
Here are some photos I just took: https://imgur.com/a/1m9EkDy
Old 01-03-2019, 05:29 PM   #15
Juanca's Avatar
Thanks Calvarez, will try and update.
