Old 10-25-2018, 09:21 PM   #1
davisbm2   davisbm2 is offline
Magician Fuel Gauge Advice Please
Hey guys, so I'm gearing up for a long ride and I'd really like to know about the Magician range on one tank of gas, and how I can get a working fuel gauge.
I don't think the bike has a fuel gauge even though it has the lights for it, which is pretty rude.
Is there an aftermarket fuel sensor I can wire in, maybe even the Hawks?
Old 10-25-2018, 09:47 PM   #2
zendick   zendick is offline
Mine goes off right after i need to switch it to reserve lol.
Best bet will probably bend the float down or weigh it down so it triggers earlier, use a multimeter to make sure yours is even working first.
Old 10-26-2018, 05:31 PM   #3
not sure about the magician but you can take the fuel line off and drain it till it runs out while the bike is level. then turn it to reserve and drain it into something you can measure how much it is then figure 20 mpg and you know how far you can push the reserve. 20mpg is probably really conservative. another way is to fill it and ride till it quits and not mileage then if you have a can of gas with you run the reserve out and note how far you went then you will know.
2016 hawk
kaw h1 400 tripple
13' long chopper in progress
2009 johnny pag bar hog
Old 10-26-2018, 06:32 PM   #4
humanbeing's Avatar
Originally Posted by davisbm2 View Post
... how I can get a working fuel gauge...
Test the ohm reading w/ multimeter from different fuel level. 100ohm (2 wire) type is de facto in china bike & easy to find something that display the differnt fuel level...
Hawk: http://chinariders.net/showthread.php?t=17413&page=2 Popular magician are as https://item.taobao.com/item.htm?id=535468820636
Old 10-28-2018, 07:40 PM   #5
if its like the hawk and has a float there are ears on each side. bend those while reading an ohm meter. one way should be around 10 and the other way around 90. just bend them till you get those readings and it will read right.
2016 hawk
kaw h1 400 tripple
Old 10-29-2018, 09:31 AM   #6
PizzaAssassin   PizzaAssassin is offline
I can get to about 180km on the trip meter before refueling, not including reserve.
fuel, gauge, hawk, magician
