Old 10-14-2018, 08:45 PM   #1
Michael92   Michael92 is offline
Flywing mx 150 parts??
New to the forum guys. Thanks for the add.
Recently i traded a 1988 honda nc50 for a 04 flywing mx150. Ive been looking and looking but havnt found a reliable source for parts. Or what would fit what. And a manual, for proper spark plug, throttle cable length, as well as clutch cable . Any suggestions would help alot ! Thanks !!!
Old 10-16-2018, 02:21 AM   #2
humanbeing's Avatar
That engine resembles to 90s kick start CG125 https://www.bike-parts-honda.com/hon.../Engine/1/3595
Modern e-start https://josemaco.files.wordpress.com...h-62ktjam5.pdf shop manual is good enough as ref material if u're mechanically inclined already
(Kick start) CDi model (in Brazilian Portuguese/ Spanish) / historical points model (Haynes) | Kymco (Big bored CG are 1st markted by them) 125/135/150 (in traditional Chinese ) manual can found via 'net...
In short:
With proper oil level. Keep centrifugal oil filter clean ( Nasty 100 000 km+ http://www.motorfans.com.cn/forum.ph...authorid=75082 bike) ***Use proper JIS screwdriver, otherwise...*** & adjust valve clearance accordingly. These simple machine will keep running forever
Spark plug is easy. Copy stock # to http://www.sparkplug-crossreference.com & get the mainstream equivalent or just buy a fits all NGK D8EA
Cables These old bike is either as
CG https://item.taobao.com/item.htm?id=527828904051 https://item.taobao.com/item.htm?id=527811109012 or
Generic chinese dirt bike that based from XL125S
https://item.taobao.com/item.htm?id=574904537647
*** Take some string as template & measures it *** Worst case u need make ur own http://www.dansmc.com/cables.htm which PiTA
Old 04-29-2019, 11:03 AM   #3
Magnum   Magnum is offline
hey do you know where i can get a clutch cover gasket and air fliter cover for a 2004 flywing mx 150
Old 04-29-2019, 03:25 PM   #4
humanbeing's Avatar
Folklore: https://www.bikechatforums.com/viewtopic.php?p=2873315 OR Modern: rtv gasket maker (use at ur own risk, too much will clogs up oil paths & the engine will gone to heaven) is the quickest way to solve the problem
If u can wait, find something similar to proper kit (Kick model CG still popular in Pakistan/ Iran or as collectible in other country) as below
If u still can't find it, there's http://chinariders.net/showthread.php?t=14466 1 of them https://item.taobao.com/item.htm?id=520146970817 CG125启动全车垫
Old 04-29-2019, 08:31 PM   #5
Thank you that helped very much. But do you also know where i can get plastics for the 2004 flywing mx 150
and a air filter cover. and a air filter
Old 05-02-2019, 12:15 PM   #6
Oh and a new exhaust to please?
Old 10-17-2020, 02:54 PM   #7
3 bikes   3 bikes is offline
Have a flywing mx150 looking for proper spark plug size
Old 11-21-2021, 05:57 PM   #8
Rehcie   Rehcie is offline
Yes, hello, what would be the proper valves clearance for my Flying 150
Old 11-21-2021, 06:04 PM   #9
Hello, my brother in law in Mexico got a flying 150. What would be the valve clearance on those?
Old 11-21-2021, 09:10 PM   #10
humanbeing's Avatar
Razz
Stolen from Kymco shop manual. Kymco is the 1st maker put that Honda config on steroid.
Old 11-22-2021, 10:03 AM   #11
TominMO   TominMO is offline
Excellent, now all I have to do is spend ten years learning Chinese!
Those are Chinese characters in your sig, but the romanized version looks to be Vietnamese. We demand an explanation. And a translation.
2021 Lifan Xpect--sold
2022 Lifan KPX
1972 Honda CT90--The Carrot
1969 Honda CT90--The Tomahto
Cheesy is the WDK (workplace drama king). Now retired. Nope, back in the saddle.
Old 11-22-2021, 02:42 PM   #12
humanbeing's Avatar
Just take the smartphone out & let the APP do the rest. Text in shop manual are in formal format so the translation result are readable.
Romanized in the successor (TL) that based on Pe̍h-ōe-jī (POJ) aka Church Romanization. http://chinariders.net/showthread.php?t=13918
