Old 09-22-2018, 02:17 PM   #1
Busy morning, trunk and chain installed , ect.
I had a busy morning. Started at the crack of dawn to beat the heat. I made the base plate out of 3/32" aluminum plate I had laying around and painted flat black to match the bike. Drilled a few holes and bolted it up.
2004 Honda ST 1300
Old 09-22-2018, 02:20 PM   #2
Next was installing the o-ring chain. The old one had a couple of damaged links from when I threw the chain a few weeks back.
2004 Honda ST 1300
Old 09-22-2018, 02:25 PM   #3
Then I finished up the morning pulling the forks off to change the oil and installed 1" pre-load spacer. I put 230ml of Dex/Merc ATF. It's amazing how nasty the oil got after 6 months. It feels so much firmer.
2004 Honda ST 1300
Old 09-22-2018, 02:29 PM   #4
My mission for the afternoon is to install LED lights for brake and turn signal on the trunk as soon as USPS drops them off. I'll post pictures of the install later.
2004 Honda ST 1300
Old 09-22-2018, 04:08 PM   #5
Got the wiring done on the bike. I used a 4 wire trailer plug so the trunk will still be removable . Now I'm just waiting on USPS for the LED's.
2004 Honda ST 1300
Old 09-22-2018, 08:37 PM   #6
I got the LED lights installed and wired up. I'll post a video of them working as soon as it finish uploading.
2004 Honda ST 1300
Old 09-22-2018, 09:27 PM   #7
Here's a short video. I tie strapped the brake lever. This should catch the tailgaters attention. Lol
2004 Honda ST 1300
Old 09-23-2018, 01:07 AM   #8
Sclark1013   Sclark1013 is offline
Wow, I thought I did a good job of installing the trunk. You killed it! Great job of mounting and lighting. Are you going to manufacturer the plate for sale?
Old 09-23-2018, 02:38 AM   #9
Essayons   Essayons is offline
Essayons's Avatar
Wow! Tha's slick as snot and twice as tasty.
2018 TT 250
2016 RX3
1979 CB750K
Old 09-23-2018, 04:37 PM   #10
Thanks guys for the compliment. No I'm not going to make plates to sell. It's just a piece of aluminum plate 6"×8"x3/32" thick.
2004 Honda ST 1300
Old 09-24-2018, 10:33 AM   #11
Thanks Katoranger for moving this to the right section. That's what happens when trying to post from your phone without your glasses on. lol
2004 Honda ST 1300
Old 09-24-2018, 11:12 AM   #12
ben2go   ben2go is offline
I'm planning to light my trunk like that too. I have light strips divided in the center so I can have signals. I also went three strips high instead of two. I'm going to use hot glue to help hold them in position.
Old 09-24-2018, 11:15 AM   #13
I did the same thing. I hot glued all the wires and connectors in place before I put the lens back on. I have room to add a third row on top. I may just do that.
2004 Honda ST 1300
Old 09-24-2018, 06:14 PM   #14
....But how many beers does it hold?
2001 Mustang GT
2004 Sportster
2018 VADER
2020 Orion RXB250L
Old 09-24-2018, 06:33 PM   #15
I would say at least a case.
2004 Honda ST 1300
