Old 09-08-2018, 05:30 PM   #1
Zebinheimer   Zebinheimer is offline
Headlight led upgrade help needed.
So I just placed my order for a new boom/vader 125 (gen 1)
Obviously looking to get this thing going propwrly from the start so the plan is;
Led bulbs to account for the battery drain
Engine bolts
Mikuni carb
I am having a hard time locating the proper bulbs to replace with.
I HAVE searched the forums and found several links but tjey are all to expired products/pages. If someone could provide an active link to the bulbs or even the carb and bolts, it may help other new grom clone buyers locate a more updated source for upgrades. Not sure whether this should be in the pocket bike or street forums so sorry for the double post.
Old 09-08-2018, 06:53 PM   #2
This Mikuni VM22 link should work :https://www.ebay.com/itm/VM22-Carb-2...72.m2749.l2649
You will also need a jet kit : ttps://www.ebay.com/itm/Carburetor-Carb-Jet-for-Mikuni-VM22-VM24-VM26-125-150-200-250cc-Dirt-Pit-Bike/121793729005?ssPageName=STRK%3AMEBIDX%3AIT&_trksid =p2057872.m2749.l2649
I cant help you on the bulbs but i do know someone has listed them before, I'll try and dig around and find them , if I do i'll post them here . ( btw dont use the vendor for that jet kit in that link, she is too slow, go to it then copy and paste description and find a US based vendor.)
2001 Mustang GT
2004 Sportster
2018 VADER
2020 Orion RXB250L
Old 09-09-2018, 01:51 AM   #3
Whisky   Whisky is offline
Whisky's Avatar
The bulbs are H11. I started off with the LED that have a fan on the base as I wanted as bright as possible. I couldn't get it to fit. I ended up with a LED that has the same base as the stock one. There is a post on this forum that has a link to the one I'm using now. 2 bulbs were 29 bucks I believe.
here`s the link---https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 I'm sure there are better out there but there isn't a lot of room behind the headlight housing.
2018 BD125-8-x21rs
ZS190/Genuine PE28
Kepspeed GP1 Exhaust
Protaper se x110 bars/grips
1/4 MotionPro throttle
Kepspeed Braced swingarm
Chimera rear hub assy
Grom Intergrated tail light
Superlite Sprockets 17/32
custom made from Japan
Chimera Swing Arm Bolt
RK MXZ Chain #420
All Balls wheel bearings
Motodynamic fender eliminator
Coremoto ss brake lines
Composimo 2.5 lower link
Grom Calipers-w/ebc pads/rotors
Michelin tire 140&120
13x4/13x7 fatties
Grom forks
Old 09-10-2018, 08:54 AM   #4
wlfpck   wlfpck is offline
www.cajunmaddogs.com
Pick up the VM22-133 kit here. That way it's a genuine Mikuni carb.
Bulbs... you'll have to search around.
Engine bolts... M8 x 1.25. Use class 10.9 or 12.9. Class 10.9 is grade 8 equivalent. Class 12.9 is a higher grade. For bolt length, don't remember off the top of my head but I've posted it before for the Icebear Fuerza (I think). You'll have to do a quick search.
Other thing you should do when you get the bike in, take the plastics off and inspect the frame. Look/inspect the welds. Look for rust. If there is rust, see if it is surface rust from a scratch in the paint... or if it is rust that went all the way through.
2020 Honda Grom
2017 Icebear Fuerza (Daix PMZ125-1) - Sold
Old 09-10-2018, 07:33 PM   #5
Gh426   Gh426 is offline
Doh! 10 or 12 Hardness on those bolts?
Aren't grade 8 bolts a better choice?!?,, I'd rather BEND a bolt than have it shatter! especially while 50+ mph... just me perhaps..
gh
Old 09-11-2018, 11:06 AM   #6
gh
Grade 8 is SAE. Class 10.9 is metric. Class 10.9 is the equivalent of Grade 8. Class 12.9 is stronger than Grade 8.
https://www.fastenermart.com/underst...d-classes.html
These Chinese bikes use metric.
2020 Honda Grom
Old 09-11-2018, 01:37 PM   #7
cbrfxr67   cbrfxr67 is offline
cbrfxr67's Avatar
"New 12V BA20D H6 4 COB LED White Bulb" is what I ordered off Ebay. One of them burned out as soon as I turned it on. The other one was ok. Not the greatest light but I wired in a switch to turn off my front lights anyways.
I ride with only the led light bar on unless it's dark. I think if you find a quality BA20D H6 led you'd be ok. For $2.65 from china I was willing to take the chance.
BD125-15
Old 09-11-2018, 10:10 PM   #8
Awesome! Thanks for the info everyone, extremely helpful. I am going to try a few of these lighting options and post some comparison pics.
As an aside: just received my mikuni carb kit, mikuni jet kit,super pumped. going to see if my local motor parts shop carries the bolts tomorrow. Next on my list is bars.
Old 09-12-2018, 10:36 AM   #9
gh
Also forgot to mention in my previous reply...
The bending a bolt instead of shatter... the factory motor mount bolts are shearing. The issue (or rather the accepted issue on all the facebook groups) is the vibrations from the factory 125cc are causing the factory bolts to shear.
That's why people are upgrading to a higher strength bolt. With grade 8 and class 10.9 being essentially the same (class 10.9 is metric, grade 8 is SAE. See previous reply for citation), if all you want is grade 8 equivalent, then class 10.9 should be fine.
If you want something stronger, class 12.9 is higher grade than grade 8.
2020 Honda Grom
