08-24-2018, 05:38 PM | #1 |
Valve stem
Anyone know where to get the tr4 valve stems for the hawk 250????
08-24-2018, 11:58 PM | #2 |
You already have that on the factory tubes, it's the threaded type. Almost all moto tubes will be TR4.
Google image it, there's so many different stem types for different applications. TR6 is offset. TR13 is rubber coated an so on.
2018 Hawk P&P Decked .040 off the head. 17/43 D.I.D. 428, NGK Iridium plug, DeCat, Wrapped pipe, Custom S.S. Muffler core, Nibbi PE30 115/35, L.E.D. Lights, Digital Cluster, USB port, Cutting Bord skid plate, Oil cooler w/ custom CRF oil filter inline, 5Wt fork oil, Rear Shock, CNC Back Rack, 30mm FAT bars, Bark Busters, ProGrips, Adjustable levers, Shinko 700’s lots of Loctite! |
08-25-2018, 08:26 AM | #3 |
Thanks...it's a tubeless tire...and the rubber is worn so it's tough to tell if it was flat or not..
Tags |
valve stem |
