Old 08-17-2018, 10:29 PM   #1
bighogman   bighogman is offline
Gy6 egr vs non-egr camshaft question
I tried to install a non-egr A9 camshaft to an 150 cc egr GY6 engine. the lobe height is not high enough. I verified the cam and it was correct. I suspect the egr head has a lower ratio rocker arm. I was wondering if i can change the cylinder head and rocker assembly to a non-egr. Also, I may want to install an 165cc or a 172cc big bore kit. Any help would be appreciated.
2016 Znen rx 150 , engine BN157QMJ
Old 08-18-2018, 12:23 AM   #2
tortoise   tortoise is offline
Originally Posted by bighogman View Post
verified the cam
Possibly incompatible cams . . typical GY6 . . GY6B?
Old 08-18-2018, 05:24 AM   #3
I put the A9 cam in it and it runs to about 45 mph. The cam lobe is not high enough. Tortoise - the specs for the cam makes sense now. it's gotta be the rocker arms
