08-03-2018, 10:23 AM | #2 |
did you lose power in upgrading to the bigger tire?
08-12-2018, 10:13 AM | #4 |
I had a million people it felt like, telling me i'd lose a ton of power...
Yet, now without changing sprockets or anything else, it steamrolls right through trails that we used to have to constantly stop and push it over fallen tree's or up a bank of the river. The ground clearance is insane now, and its 5+ inches wider too, so it's handling the trails just as good as the Suzuki King Quad is, the only downside we've had so far is the tires are soooo huge that the plastics do not protect you from mud or water at all, even the smallest puddles will coat you head to toe. Today i'm adding new a new clutch cable and lever, and new throttle cable and lever, gonna also see how crazy it gets by dropping the front sprocket down to 11 from 15, and i've got a new chain and back sprocket to go along with that. The nice thing is, even with the new tires on a very steep incline hill i can make a full stop and turn the machine off.. then start it back up and climb still even with my 300lb butt on the bike. So, i figure if i drop the front sprocket and make a few other changes, my low end will get insane even with the big tires. The only thing i hate about my tao these days, is that it's a manual and none of my family or friends can really ride one on trails. They do perfectly fine around the fields and yard, but the second we start doing rough stuff they stall a lot because they aren't great at really balancing the clutch. Makes me wish i had gotten the bull sometimes. Oh another thing, if you get tires this big, be warned.. getting onto the quad is very similar to getting into a pickup truck that doesn't have the nerf bars, it's really high. And you have to get 2" spacers on the back tires. |
08-12-2018, 01:22 PM | #5 |
Thanks for the update. Keep us posted about the sprocket mods.
08-12-2018, 05:32 PM | #6 |
So no smokey burnouts!! but tons O torque!! looks great, you can rig up a wide body kit.
g |
10-01-2018, 02:36 PM | #7 |
Hey where did you pick up a new clutch lever and cable from?
10-04-2018, 10:33 AM | #8 |
do you have a link to the tires
12-28-2019, 02:31 AM | #9 |
Are the front tires 25x11-10 also?
06-27-2020, 09:40 AM | #11 |
I'm thinking about going 24x11-10 on the back and 25x9-10 on the front on my Bull
07-13-2020, 10:26 AM | #13 |
I've gone through a couple sets of tires on my Rhino. 1st used was Kenda Bear Claw 23x10-10 rear. Good traction but very stiff ride even at 2psi. Changed to GBC 23x10-10 that ride better and are wearing better. They have a slightly more rounded profile. Current fronts are Schnef 23x7-10 that I like. Good ride and steering grip with the center ridge. 23" tires give me enough ground clearence for the riding I do.
07-14-2020, 08:48 AM | #14 |
I was thinking maybe about adding an inch or two,24x7-10 in the front and 23x11-10 on the rear,maybe 25" in front and 24" on the rear,I thought about the Kenda Bear Claw's for the rear,I don't know yet,so many choices, and haven't found a tire that I like for the front yet,definitely got to be 6 ply.
