07-19-2018, 11:38 PM | #1 |
Video of backfiring after mods and jets
Here is a video of my bike backfiring as i let off throttle. I have ebay exhaust, pod filter, and CSC recommended me going to a 115 from i believe stock was 108 and a 40 and stock is 30 something. Should i go with different jets? I know there is a screw underneath that i needed to cut a slot in should i back it out more or screw it in? any and all ideas welcome
----------------------------------------------------- "Take it easy, if its easy take it twice" 2015 CSC TT250 -Ebay exhaust -Exhaust wrap -Wingsmoto Air bent filter (POD) -Outerwears prefilter for POD -CSC jets 115 and 40 -15 weight front fork oil -47 tooth JTR269.47 rear sprocket -JT 428 HDR (128 link) Heavy Duty Drive Chain -LED tail light bulb -Auxbeam LEDF-S2 headlight bulb -Brush hand guards -30L removable tail box (ebay) -3.1amp waterproof usb charger |
07-20-2018, 12:50 AM | #2 |
This is what my spark plugs look like after riding a few miles with new jets
07-20-2018, 04:28 AM | #3 |
what carb are you using??
what region of the country are you located? what's the altitude there? |
07-20-2018, 04:44 AM | #4 |
it's back fireing on a closed throttle...
most bikes do that these days because of the exhaust air injection system to burn unused fuel that enters the exhaust while on a closed throttle to give clean exhaust emissions.. fuel + air + red hot cat = BANG You notice it now because the new pipe dose not baffle the sound of the back fire as much... just gut the Air injection system off the bike & plug the air inlet in the head.... You want to hear my XT660R on a closed throttle.... ...
07-20-2018, 07:53 AM | #5 |
Im using stock tt250 carb and and purchased jets from CSC. I am in central Florida about 50 above sea level max. I dont recall hearing it with factory jets though but i have only had the (used 2015) bike for a less than a month and started modding it. (although previous owner did have a random straight pipe off of a smaller 80cc (maybe) but is was loud and barely on the bike just swinging around but i dont think that means anything just giving a back story. Also before, i could start bike just by touching the button now i need to pull on the throttle just ever so slightly. (i have never had to use choke before jet upgrade and after upgrade)
07-20-2018, 07:57 AM | #6 |
What does the air injection system look like. are they the hoses going into the side and bottom of the air box. i left them attached even though im not using the airbox any longer
07-21-2018, 11:09 AM | #7 |
Just block it off like this on your TT, this is on my Hawk.....but I have a TT250 head on it.
https://photos.app.goo.gl/UJcpNcJEbZKW6gwG7
1991 Kawasaki KLR250 |
07-21-2018, 11:26 AM | #8 |
It looks/sounds a bit lean... i would back the air fuel mix screw out a half turn and try it.... looking for a bit more caramel color on the plug... otherwise bump up to the next larger jet size...
07-22-2018, 02:49 AM | #9 | |
07-22-2018, 03:05 PM | #10 |
I recommend a PCV valve in the line coming from the crank case. Install it so the crank case can breath out but can not inhale...ARH
07-22-2018, 03:34 PM | #11 |
Yes, just use high temp copper silicone gasket maker for that blockoff plate, use a small filter on the crancase breather or a PCV valve like ARH suggested, I used the PVC method.....take the hose to the parts store and find one that will fit in the vent hose good.
07-22-2018, 08:57 PM | #12 |
Plug or plate all three places ..move on.
P.A.I.R system delete in first mod vid
07-22-2018, 11:23 PM | #13 |
Technically these bikes are dual exhaust..
07-23-2018, 07:55 AM | #14 |
What octane gas are you running in the bike? Lower octane fuels detonate quicker so you may see improvement if you fill up with a 93 super premium fuel. It may not make a difference however.
2018 RPS Hawk 250cc Mods so far: 1. Mikuni VM26 Carburetor w/#115 main jet 2. 17T/45T JT sprockets 3. JT 428 X-ring chain 4. Air box mod 5. Hawk Digital Cluster 6. Aftermarket IMS shift lever 7. Performance Aftermarket Exhaust 8. 295mm Nitrogen Gas Monoshock, 20W oil front forks |
07-23-2018, 09:42 AM | #15 |
It even does one soft puff after i turn bike off. I did the pvc inline on the crank case i even put a tiny cone filter on other end of pvc valve just for added security. I didnt do the plate yet but i did pinch hose with vise grips and had it run for 15 min to warm up and then tried revving engine and it still does it along with the puff after i turn it off. i didnt close off the hose going into carb though i didnt see the video showing that one until after my experiment. I do run the lowest grade fuel but really i have never had a bike that required that and i have changed the exhaust on all my bikes, 4 Ninjas, 1 CBR and a Suzuki Intruder 750, Never really messed with changing out any of my dirt bikes exhausts though but i was young then.
