06-22-2018, 11:53 AM | #1 |
Preping a new Hawk
So I'm doing all the usual mod's as I assemble my bike. So glad I am swapping out tires and tubes, as I just changed out the rear and the rim strip wasn't even on the spoke nuts on half of the rim. Tubes had no power. It looks like the tire was drug or skid as 10 of the knobs have their leading edge worn, a few fairly good!! My only screw-up so far, I ordered a non o-ring chain, gonna run it anyway, gotta read a bit better! Thanks for all the tips I've read, including the stainless 8mm exhaust studs/nuts, just came in. Now if I could only get my Cluster and Oil Cooler??
06-22-2018, 11:59 AM | #2 |
A non Oring chain will be fine. Just soak it in a synthetic gear oil before installing it. Whenever you do clean it just soak it again. I've put over 2500 mile on the stock chain without significant wear or stretching. So a good chain should last just as long or longer.
2024 Linhai 300 ATV 4x4 2023 Lifan Lycan 250 Chopper 2023 Venom Evader 2022 Lifan KPX250 2020 Kawasaki Vulcan S (Sold) 2004 Honda ST 1300 2016 Black Hawk 250 (sold) Keihin PE30 carb,125 main,38 slow.Pod filter,ported & decked head 10:1 CR,Direct Ignition Coil,15/40Sprockets,NGK DPR8EIX-9,De-Cat,Dual Oil Cooler,Digital Cluster 2016 Cazador180 XL 2014 Coolster150 JerryHawk250.com My YouTube Channel Last edited by JerryHawk250; 06-22-2018 at 01:02 PM. |
06-22-2018, 12:02 PM | #3 |
Agreed; I've never used an o-ring chain. I've remained with 428H chain, usually by DID or RK, although I have a new Unibear in the box.
06-22-2018, 12:13 PM | #4 |
so cheap chains work uni bear 15.00 ebay the rk h 428 128 around 17.00,i want the the rk mxz ,is stronger i found an oring chain for yamaha xt250 for 34.00 sledpartsguy seems reasonable when compared to the rk version for 75.00 +
the 428 128 link is hard to find in the stonger chains ,thinking about 130 link an take few out with a 16th front an 45 rear
06-22-2018, 12:35 PM | #5 |
If you are going to buy an O-ring chain, then spend the money on a good brand or just stick to a high quality standard chain. The most common failure on cheap o-ring chains is the o-rings themselves, and at that point you have a worthless chain.
I speak from personal experience on that one. I would spend double the price on that RK chain before buying some unknown brand. I have nothing against standard chains, but from my own experiences with them I can say that they (o-ring chains) do tend to last longer and are much more forgiving to harsh environments or owner neglect. There is a reason most new bikes are almost all coming as standard with O or X ring chains. My personal favorite is DID VX2 chains. I have had one outlast the sprockets it was installed with on a previous bike of mine.
06-22-2018, 12:37 PM | #6 | |
06-22-2018, 02:48 PM | #7 | |
