05-08-2018, 04:37 PM | #1 |
Quick tube question
I have looked and TR-4 is the valve size I guess. After searching saw people used different ones, now my feeble brain is just befuddled. Always had bikes with tubeless wheels/tires. Anyway thanks in advance. Here is the simple question.
What size tubes do I order for a hawk 250? If you want to add a link for amazon . Got a set of shinko 705s that need to go on. Promise I am not lazy, just easily confused.... |
05-08-2018, 04:41 PM | #2 |
Front https://www.amazon.com/dp/B00E0OYQ8Y...v_ov_lig_dp_it
Rear https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 Simple enough you lazy good for nothing Glad to help.
05-08-2018, 04:55 PM | #3 |
im so lazy i put fix a flat in my front!!! good so far
05-08-2018, 05:00 PM | #4 | |
timcosby, that is super ultra lazy. kudos. But my son is going to ride this bike so I want it to be reliable and safe. |
05-08-2018, 05:03 PM | #5 |
I just realized that the links I provided are out of stock. But at least you will have the information on the tubes to find them. These are the tubes I purchased. The original tube on the Rear blew out in a couple of months then the front 2 months later.
05-08-2018, 09:40 PM | #6 |
I assume the harder you ride it the more friction and flex causing them to wear out faster. I have not beat on mine. it only has 500 miles on it as I commute on the big bike, it is just more comfortable in traffic and if I need to punch it I have 10x the power of the little hawk. But make no mistake, love my hawk.
05-09-2018, 02:42 AM | #8 |
The stock tubes are just laughably thin and made from poor quality materials. I have run tubes in tube type tires, ridden the hell out of them, and the tubes were still good. I always change tubes when I replace tires if they wore out from mileage, but there are people that re-use tubes and put many thousands of miles on them.
05-09-2018, 07:31 AM | #9 | |
