Old 04-25-2018, 08:55 PM   #1
Hammertime   Hammertime is offline
Doh! Minki carb not shutting all the way
Put carb on Vader 125 and can't get it to shit all the way a run wide open started
Old 04-25-2018, 09:12 PM   #2
Do you need long throttle cable
Old 04-26-2018, 09:56 AM   #3
ben2go   ben2go is offline
Are you talking to yourself?
Give the cable all the slack you can and check the routing to make sure the cable isn't kinked. If that is good and the problem persists, you may need a different cable. I'm not familiar enough with the small bikes to advise on which cable.
Old 04-26-2018, 10:55 AM   #4
Is it possible that the slide is in backwards?
Old 05-06-2018, 10:16 AM   #5
Lkhangee   Lkhangee is offline
The needle might be bent. Or might be stucking int the emulsion tube which usually happens when the needle jet is improperly seated. (the jet through which the needle goes in /out)
Old 05-06-2018, 08:34 PM   #6
Arcstriker29   Arcstriker29 is offline
Arcstriker29's Avatar
When I swapped carbs, it took some messing around to get the throttle right, but first like some one else mentioned, check to make sure the slide is in correctly, it might need to be rotated 180 degrees... OR see if there is any play at all when you twist the throttle, or is it tight and only turn a short distance? I try to set mine so there is minimal play, but not so the cable is being tugged when released. A lot of these carbs have different cable settings from 1 to another.
Old 05-07-2018, 09:58 AM   #7
Adjuster's Avatar
My guess is the little metal ferrule at the end of the throttle cable is not seated all the way down into the nipple on top of the carb. Essentially causing your cable to be just slightly shorter.
