Old 04-24-2018, 01:04 PM   #1
Meloman   Meloman is offline
Help ! Shark fin attack !!
I noticed on my new TT250 that the shark fin was facing the wrong way (forward). I thought it was a flat piece, but it’s kind of warped. So when I turned it around it comes within 1/4” of touching the chain. That doesn’t look safe. Are they supposed to be flat ?
Old 04-24-2018, 01:12 PM   #2
The one on the Hawk is flat. Just take a heat gun to it to flatten it out.
2020 Kawasaki Vulcan S
2004 Honda ST 1300
Old 04-24-2018, 03:39 PM   #3
They all come backwards, or at least all the ones I've heard of. never heard of a warped one. Let CSC know. I'm sure they'll send one out asap....or try the heat gun idea.
Old 04-24-2018, 08:19 PM   #4
not sure it does anything other than sit there anyways!!!
2016 hawk
kaw h1 400 tripple
13' long chopper in progress
2009 johnny pag bar hog
Old 04-25-2018, 10:39 AM   #5
From what I gather, it's supposed to deflect things (sticks? twigs? gremlins? fingers?) from getting sucked up into your chain and sprocket.....which having them mounted backwards must guide all foreign objects right into your chain and sprocket?
Things to ponder.
Old 04-26-2018, 02:27 AM   #6
2LZ, yours is flat on your TT ?
Old 04-26-2018, 10:59 AM   #7
Is yours like this?
Old 04-26-2018, 01:46 PM   #8
You seem to have a smaller sprocket. With my stock sprocket the fin is about 1/4” away.
Old 04-26-2018, 01:48 PM   #9
I wouldn't worry about it being a 1/4" away. The sprockets not going to move side to side.
2004 Honda ST 1300
Old 04-26-2018, 03:38 PM   #10
First bent one I've ever seen. Like Jerry says, I wouldn't worry. If the chain hits it, it will carve its own path, ;-)
If I were you though, I'd email CSC with this pic and have them send you another. They are very good about warranty.
Old 04-26-2018, 03:49 PM   #11
I spoke to CSC and their position is that the forward facing fin is the correct way to be installed. Granted the sprocket isn’t moving but something could potentially get wedged between the fin and sprocket and knock off or break the chain.
I’ll call CSC again and have them check their parts stock for comparison.
Old 04-26-2018, 03:51 PM   #12
Heat Gun
2004 Honda ST 1300
Old 04-27-2018, 10:09 AM   #13
If, in fact, the Hawk shark fin is flat, where can I buy one ?
Old 04-27-2018, 10:26 AM   #14
Biker_Andy   Biker_Andy is offline
Biker_Andy's Avatar
A heat gun or blow dryer on high heat and a little force should straighten it out. I'd leave it on the bike get it nice and hot then pull untill its straight. You may need to wedge something between it and the sprocket to keep it in position like that until it cools but it will probably stay however you bend it once it's warm.
Old 04-27-2018, 10:33 AM   #15
Biker_Andy's Avatar
The shark find is officially called a...
Chain Block P/N: ZT28-102 $2.95
I'd try bending the one you have and worst case you buy a new one from CSC.
