03-29-2018, 09:14 PM | #1 |
storm headlight
hi does any body know if i can change out the stalk headlight on a storm 250 for the one on the brozz ?
03-30-2018, 12:24 AM | #2 |
If it's the same is the enforcer then no. The wiring harnesses and front fender are all different and you have to make a new mount.
03-30-2018, 12:02 PM | #3 |
Yeah, I have a Bashan Shark and I can't find a plug and play LED for it.
Bashan Shark, Keihen PZ30 Carb, Pilot 40, Main 120, Uni Filter, Exhaust, MSR Shifter, and some stickers. |
03-30-2018, 05:24 PM | #4 |
thanks for the help.
03-31-2018, 08:24 PM | #5 |
i am looking to just change out the shroud for looks . i would not mind using the storms bulb and wiring.
04-01-2018, 11:00 AM | #7 |
Humanbeing
Is that a kit ? do you have the link or tell me the name of it, HL ? |
04-02-2018, 05:55 PM | #8 |
04-05-2018, 07:37 AM | #9 | |
04-13-2018, 07:16 PM | #11 |
This kit I bought has needed some modifications to make it work due to the Storms housing.
The mount with two tabs needed to be grinded down and glued in the housing to mount the Led, It does not lock in at all. the wire harness needs to be replaced also. Make sure the Led is in a upright triangle when it is in the housing at the time you glue in the plastic mount. The Led has two sides on a angle that are the low beam and the bottom is high, it must be positioned correctly. I might replace the harness on the bike so I can just buy a replacement bulb and not rewire each time. This is a really simple thing to do. I wouldn't let it stop you from upgrading and this kit has everything you need to do it. |
