03-27-2018, 12:58 AM | #1 |
2017 Bashan Storm gauge upgrade to Samdo 5 gear lcd.
I purchased the samdo 5 gear LCD half way through I realized I hate wiring. Any diagrams on the electrical or how to hold one up. It's the Honda clone one. I know skiforce purchsed one fir an enforcer.
Thanks again. |
03-27-2018, 12:58 AM | #2 |
That's supposed to say how to hook one up thanks.
03-27-2018, 01:00 AM | #3 |
03-27-2018, 06:09 AM | #4 |
PM the folk from http://chinariders.net/showthread.ph...831#post273831
In theory they had Chinglish instruction. Anyway most of this shape are as B2912 Alibaba domestic version https://detail.1688.com/offer/563739160073.html | Aliexpress: https://www.aliexpress.com/item/Univ...786164844.html U can testing the function by jumping wires (those lights: gear position/ N / l& r ... ) / adding dummy load (fuel position sensor http://chinariders.net/showthread.php?t=19680) b4 connects to bike RPM's signal often can taken from http://www.chinariders.net/showthrea...958#post260958 --- About color code http://chinariders.net/showpost.php?...3&postcount=11
03-27-2018, 07:32 AM | #5 |
03-27-2018, 08:07 AM | #6 | |
One other thing. This cluster made me get a 120cca battery because the battery that comes on the bike was not strong enough to start the bike and maintain the clock time. The battery is much bigger, so I had to resize the battery bracket. I just used the original bracket, broke the welds, and rebent it to fit. Last edited by Skiforce75; 03-27-2018 at 09:38 AM. |
03-27-2018, 10:49 AM | #8 |
Thank you all for the quick responses. I will try this and let you know how this turns out I will take some photos after with some video.
03-27-2018, 09:02 PM | #9 |
Priceless info, thanks!
03-28-2018, 03:33 PM | #13 |
Do you have pictures of the cable and attachment for the sensor on the wheel. OR how did you do that?
Thanks. |
03-28-2018, 07:17 PM | #14 |
Does this help?
https://m.facebook.com/groups/596668...01991033291825 Last edited by Skiforce75; 03-28-2018 at 08:54 PM. |
