01-29-2018, 03:40 PM | #1 |
Chain Binding
I recently changed my chain and have noticed the new one wearing out very fast and needing adjustments more frequently, about every 150 miles or so. The first two chains lasted me about 6,000 miles each. After about 2,000 miles this chain whips up and down while riding because it is binding on the rear sprocket after the master link. As the bike rolls the chain gets loose, super tight and then loose again with each rotation.
Although both sprockets have between 10 and 15k miles they appear to be in good shape. I have ordered a new sprockets and chain and I'm hoping this solves the problem, but I don't like the idea of going through a new chain every 2,000 miles. I have been good about checking sprocket alignment and that seems to be good even now. I feel like I do a ok job of keeping the chain lubed. Is there any reason the chain would bind right after the master link? Does this sound like worn sprocket(s) or did I install or maintain the chain wrong?
2013 SSR XF-250 |
01-29-2018, 03:59 PM | #2 |
Sounds like dry or corroded rollers to me. A new chain shouldn't have binding issues like that.
What brand and type (standard or o-ring) of chain is it?
01-29-2018, 05:57 PM | #3 |
A few more Q's
Did you change out to new sprockets when you did the chain? What is the sprocket(s) tooth count and how many links in the chain?
01-29-2018, 09:21 PM | #4 |
It is a standard RK 520h 112 links. I did not change the sprockets since I thought they looked ok. I will try and get some pictures of both. I replaced the last chain because it was doing the same thing and I figured it was just worn out.
The rear sprocket is the original 43 tooth and front is a 16 tooth that I put on right after the bike was broken in.
2013 SSR XF-250 |
01-29-2018, 09:35 PM | #5 |
Have you checked the bolts on the sprockets?
2006 roketa 200cc 1971 Yamaha xs650 2x 1980 xs650, 1 is a café, other is a chopper/brat 1972 Honda xl250 2x early 90's Honda rf600 parts bikes more mc junk laying around. |
01-29-2018, 11:30 PM | #6 | |
01-30-2018, 12:46 AM | #7 | |
01-30-2018, 02:49 AM | #8 | |
Something I didn't get to state (I was at work at the time) is that if the chains you are buying sat on a shelf for a while, all of the grease or lubricant in the chain has likely dried up. If you don't know for sure that your chain is relatively new, then the best thing you can do is give it a good bath in your chain lube of choice, heavy gear oil, or a hot paraffin wax. By bath, I don't mean spray it, I mean immerse it and let it sit for a while to let said lubricant work its way into the rollers. Also, if the only link that is binding is next to the master link, then there is a chance that one or more of the plates near that link may have been bent. This happens a lot when people use pliers to help press the master link together. If immersing the chain and articulating that particular link doesn't free it up, then I would assume a mechanical issue like said bent plate.
01-30-2018, 09:14 AM | #9 | |
01-30-2018, 04:45 PM | #10 |
Angus I did check the sprocket bolts and eveything was snug.
Megadan I didn't soak the chain before installing but I will be sure to break in the new chain right. Right now one half of the chain is incredibly tight and the other half is incredibly loose to the point it is wearing the upper chain guard as it swings up and down. I am ordering a new front sprocket and chain today from Amazon and hopefully my rear sprockets from Taobao arrive in time for the weekend. I will have the choice of a 39 or 43 for the rear and a 12, 15, and 16 up front. Also wondering, are O ring chains worth the extra money?
2013 SSR XF-250 Last edited by dh; 01-30-2018 at 04:46 PM. Reason: missing info |
01-30-2018, 05:45 PM | #11 |
I think they are, but that is entirely subjective. Standard chains can last a long time if properly prepped and cared for. I have had great life out of D.I.D o ring chains, and my EK SROZ chain had 1400 miles on it when removed and has uet to stretch or bind. I could probably get several more thousand miles on it.
