11-25-2017, 09:56 PM | #1 |
Wow, New Hawk, Endless Hassle...
So I have been working on a jetting issue on my new Hawk 250 and think it is finally good, except... now I couldnt test it out fully since my tire went flat during my ride causing me to almost crash. So I got home and tried to fill it will air but it didnt fill. So I then tried to fill it with Fix-a-flat so I could desperately go back out to test my jetting but the fix-a-flat poured right out the sidewalls like a leaking dam.
What may this new issue be?? I have owned Japanese atvs and bikes my whole life and never had an issue with a tire not filling with air, and on top of that, having fix-a-flat pour out the sidewalls. WHAT IS MY ISSUE HERE???? I am almost regretting this Hawk 250 purchase (from Txpowersports.com) as its been over a month now and its endless puzzles to figure out... Last edited by HawkTwoFifty; 11-25-2017 at 10:42 PM. |
11-25-2017, 10:09 PM | #2 |
The Hawks tubes are not so great. I would go out and get a set of thicker tubes and replace both of them.
Once you get it sorted out, I'm sure you will be very happy with it. My previous bikes were Japanese so I know the frustration. When I went to get back into riding I went to the Honda dealership and had sticker shock on the cost of a new Honda, nearly $6k. I got my hawk for $1,200 and it required tinkering. But once it was dialed in it proved to be quite a nice bike. Good luck and hang in there. |
11-25-2017, 10:13 PM | #3 | |
I havent even put 13 miles on my hawk yet!!!!!! Are the inner tubes made out of paper?? What else should I be aware of going bad on this bike? I am starting to regret buying this bike. |
11-25-2017, 10:22 PM | #4 |
If my tubes went bad after less than 13 miles, I think the manufacturer of the Hawk 250 should pay for this!!! This is ridiculous.
Does anyone have the contact info for the manufacturer of the Hawk? The manufacturer of the hawk is Haosen right? I bought this bike from TXpowersports, should I contact Haosen or TXpowersports with my complaint? Very aggravated. |
11-25-2017, 11:15 PM | #5 |
I got my tubes from CycleGear. There is a local store here in CT that I just showed them my bike and they pulled them off the shelf. I'm sure I could have saved a couple of bucks by getting them online but I like to support my local store. Because they grabbed them off the shelf I don't remember the size. IT will be a matter of time before other folks here chime in with links to the proper tubes.
As for after purchase service, good luck. TXpowerports is not known for their service. The hassle of dealing with them is not worth the $20 for a tube. |
11-26-2017, 12:37 AM | #6 |
Tubes
I had the factory front tube come apart at 61 miles. Some people have mentioned that the factory Hawk tubes are made by the Chinese Condom Company!
I bought IRC heavy duty tubes from Amazon. I also replaced the rim strips because the rear rim strip had a tear in it from a spoke nipple. They are also made by IRC. Since I spend at least 50 percent of my Hawk time on paved roads, I switched out the knobby tires for Shinko 244s. I really like the 244s! I understand about being frustrated with the lack of dealer support. I was ready to sell my Hawk and by a new Kawasaki KLX 250. Then I saw the price tag attached to that new KLX! Which is why I bought new tires, tubes and rim strips! Like everyone else has said, once you get the bugs worked out, the Hawk is a nice little dual sport motorcycle. Good luck & hang in there!
Dan-O -2018 Tao Tao HellCat - DOA -2016 Hawk 250 - Kitty Hawk - eBay exhaust, Mikuni carb(120 main/30 Pilot), airbox mod with K&N filter, digital cluster, total LEDs, 17/45 sprockets, RK chain, Shinko 244 tires, trunk, aftermarket levers, burrito tube, skid plate, Sargent Cycle Seat... -2003 HD Sportster 100th Anniversary -1999 Buell X-1 Lightning - Race kit, Buell Seat |
11-26-2017, 02:53 PM | #7 |
Tubes are one of the many known weak points of these bikes from the factory. I had seemingly better luck than most and managed to get to about 1300 miles before my rear tube decided to die. The tubes are very thin and not made of the best rubber. Replace both and be happy. Get a good brand and replace both as suggested. They aren't an expensive thing to replace.
11-26-2017, 09:12 PM | #8 |
if you have fixaflat comming out the sidewalls you got more problems than tubes!
11-26-2017, 10:00 PM | #9 |
I think they were: Front: 80/100 21 Rear: 110/100 18.
But of course cycle gear is out of stock: https://www.cyclegear.com/gear/msr-heavy-duty-tubes Someone please confirm my sizes. |
11-26-2017, 10:33 PM | #10 |
I had very good luck with my original tubes. I put at least 600 miles on them. However, when I changed tires. The spoke rubber band strip was in bad shape. The ends of the spoke fittings were rubbing holes in the rubber rim strip and leaving marks on the thin tube.
11-26-2017, 10:36 PM | #11 | |
11-26-2017, 10:43 PM | #12 | |
11-27-2017, 04:28 AM | #13 | |
ARH is right.... tape the rims... All my rims get 3 layers of 32mm duct tape over the rubber rim strip.. theres a tape made by 3M that is getting quite a following to turn spoked rims into tubeless.... can't remember what it's called.. .
11-27-2017, 05:30 AM | #14 | |
https://www.3m.com/3M/en_US/company-...3241577&rt=rud works in that job...
11-27-2017, 07:51 AM | #15 | |
