Old 11-17-2017, 04:05 PM   #1
TGubbins   TGubbins is offline
TGubbins's Avatar
FNG with 3x CG200 Need Head Gasket:RSVL,CA
Its my sons fault..
He bought the first one, Then couldn't resist a second one. And now picked up a third.
All 3 are basically the same bike: Zongshen CG200cc ????
Seem to all have the 163FML motor but badged as Yamoto, Cobra and a KPX.
Yamoto ran out of oil and torched the con-rod bearing.
Work in progress fixing that..
However I am desperately searching for a HEAD GASKET!
bought a seal kit that seemed close but no joy.
I can get crafty and cut other gaskets if I have to but need a fresh head gasket.
See pics, any leads or wisdom appreciated!
Tim in Roseville, CA
Old 11-17-2017, 04:10 PM   #2
TGubbins's Avatar
photos didn't seem to happen.
Try this?
https://photos.app.goo.gl/m0UlPjAv824LuwIM2
Old 11-17-2017, 05:38 PM   #3
humanbeing's Avatar
OHC (CB)
OHV (CG)
Old 11-19-2017, 01:15 PM   #4
TGubbins's Avatar
that set of CB200 gaskets with the cylinder kit looks like a match! how to get! where can i buy? can i buy just that gasket set?
OHV vs OHC ?
162fml vs 163fml?
this set looks like what i need:
http://www.ebay.com/itm/180483848185
Old 11-19-2017, 02:28 PM   #5
humanbeing's Avatar
https://www.ebay.com/itm/292144726118 is one of those matches 63.5mm
btw. that shape also found in the weirdo 69mm which are difficult to find in US
Old 11-19-2017, 07:46 PM   #6
TGubbins's Avatar
excellent! thank you for the help!
You may know this answer so i will ask:
what is the crankshaft cam chain sprocket alignment?
align tooth or trough to tdc keyway?
i foolishly pulled mine off the crankshaft without marking it.
as a last resort i could open up one of my other 163fml cases to see but i would really rather avoid it.
Old 11-19-2017, 08:51 PM   #7
humanbeing's Avatar
Official answer is in http://www.ctx200.com/files/xl200_workshop_manual/
WiSiWYG in http://www.motorfans.com.cn/forum.ph...uthorid=343764 15# & 16# Google 's translation is readable
Old 11-20-2017, 05:07 PM   #8
TGubbins's Avatar
Excellent resources! THANK YOU
Sadly not really getting the angle to see what I need.
I'm going to start a new thread as this has headed way off gaskets
THANK you HumanBeing
cg200 163fml headgasket
