11-01-2017, 08:38 PM | #1 |
What cc is this?
I bought a 2006 roketa for $40. Guy said its a 250
The tag says 200. Its a ohc, with leads me to believe its a lifan 250 What is it?
2006 roketa 200cc 1971 Yamaha xs650 2x 1980 xs650, 1 is a café, other is a chopper/brat 1972 Honda xl250 2x early 90's Honda rf600 parts bikes more mc junk laying around. |
11-01-2017, 09:37 PM | #2 |
in serial number maybe
11-01-2017, 10:06 PM | #3 |
I think OH cam rules out a Lifan. Maybe a Loncin.
"Its not WHAT you ride; its THAT you ride" Last edited by wheelbender6; 11-01-2017 at 10:10 PM. Reason: spelen |
11-01-2017, 10:09 PM | #4 |
Lifan made a 200cc OHC about 10 years ago. One member on here had one on an old Honda 200x.
11-01-2017, 10:35 PM | #5 |
The model number on the neck says 200gy. So thats that.
My crazy days are long gone. Although i still run around on my xs650 chopper. No blinks, no horn, no rfront fender. I figure at 250 lbs, i should gear it pretty tight and stay off the road. Wich is fine. Im just looking for single track crawler. I have plenty of street worthy bike to scare the kiddies
11-01-2017, 10:42 PM | #6 |
There's an engine number down by the shift lever. That will tell what you have.
11-02-2017, 12:27 AM | #7 |
Barrel height tells u the answer
Normal honda clone: 63.5 (196) https://item.taobao.com/item.htm?id=39517848641 | 65.5 (223) https://item.taobao.com/item.htm?id=35517374143 Weirdo 69mm: https://item.taobao.com/item.htm?id=534858752508 | https://item.taobao.com/item.htm?id=533985048419
11-02-2017, 11:50 AM | #8 |
I have that very motor and the stamp near the gearshift is incorrect. The only way for me to determine actual displacement was to remove the head and measure.
11-02-2017, 11:54 AM | #9 |
So what was it? Is it bore x stroke?
11-02-2017, 12:16 PM | #10 | |
This is what I dug up:
I found it here: http://www.chinariders.net/showthread.php?t=12613
11-02-2017, 12:20 PM | #11 |
For the unfamiliar, one calculation is bore squared x stroke x 0.0007854 = 193.48cc
11-02-2017, 02:12 PM | #12 |
It should more accurately be V = πr²h, where r - Bore radius, and h =stroke.
