10-16-2017, 09:05 AM | #1 |
electrical issue
hello all,
I have a 2016 taotao GK110 kart with an electrical issue. any input is greatly appreciated. main issue was/is no spark. I replaced the cdi, but this did not fix the problem. parts being so cheap, I went ahead and replaced, stator/pick up assy, volt reg, coil, remote box,battery, and spark plug. still no spark. it cranks just fine, but no fire. it has a manual choke. ive looked at wiring schematics, which seem to vary widely. the only fuse I can find in the system is in the electrical box. it is good. someone told me there may be a diode or resistor in the wiring harness, but I haven't seen any. looking at wiring diagrams, I only see these on machines with electric or auto choke. what am I missing ??? any input is greatly appreciated. |
10-16-2017, 12:14 PM | #2 |
Try removing the key switch pin from the CDI connector. Normally only key-off grounds the CDI, but there may be a ground fault in this circuit between the switch and CDI. If the engine does start, kill it by separating the pick-up connector.
10-16-2017, 03:46 PM | #3 |
thank you for the info. I will give that a try.
02-06-2018, 10:49 AM | #4 |
Make sure the kill or stop switches are working. Bypass them temporarily to see if they are interrupting the spark.
Thanks |
02-06-2018, 05:57 PM | #5 |
If this is a little childs cart it most likely has a kill switch with a tether in the rear so it can be yanked if the kid gets out of control.
05-02-2019, 09:40 PM | #6 |
Did you find a solution?
My grandson's go kart has a similar problem. I have tried everything listed plus bypassed the parental control circuit along with taking out the middle kill switch pin on the CDI. No fire at all. Another anomaly which should have noting to do with spark is the gear selector indicator has all the letter segments lit. |
05-02-2019, 09:56 PM | #7 |
It is possible the gear indicator switch in the tranny is buggered or it’s wiring, and killing spark .I have no idea what style of engine is in your machine which will make a difference to where the switch is actually located ,but most of the switches seem to be located in the front sprocket area ,
05-03-2019, 08:13 AM | #8 | |
The kart is the same model as mentioned in this thread, a TAO 110 cc. |
