08-12-2017, 06:56 PM | #1 |
150 cc jets
can any one tell me the jet size for a 150 cc gio... stock carb.... I have a low idle jet PLUGGED..... I have troed to clean it out with a wire ,... like I always do... this one is plugged.!!!!! I tried battery acid to eat it out... and How I have it soaking in MURACTIC ACID.... I will pick up some small drill bits Monday from GREGGS supply... I thought I moght drill it out to the right size if I find out the size for the idle jet... I do not need the performace jet size.. just factory or close to it... never had a jet plugged like this one... ok.. I will post if it becomes free with the acid.. I know carb cleaner does not clean plugged jets..
08-12-2017, 07:01 PM | #2 |
ebay jets
I see on ebay( afterthought check ebay) Set includes one piece of main jet size 100 and one piece of idle jet size 35
is this what most are???
08-12-2017, 10:21 PM | #3 |
Which type? PZ** or PD**J
--- Why not boil it in water based solution ? Those acid trick are too dangerous...
08-14-2017, 07:45 PM | #4 |
jet
Hello.... this jet is plugged... WOW... I have bought a 1/64 drill ... too big... and a smaller one... maybe 1/128/// still too big... I can not believe it... I could change the jet ,,, but I thought I CAN CLEAN IT...... not I can not.... let you know how I am doing.. thanks for the idea..
08-16-2017, 02:15 AM | #6 |
I growing up w/ BAD gas & that trick was learned back then.
The boiling water acted something as Ultrasonic cleaner (shake into smaller portion) / high temp dissolve that sticky mess to semi-solid... RESULT: Most of time it will cleared out... | Add some detergent/ vinegar or whatever for better result...
