Old 08-05-2017, 12:32 AM   #1
Robertk   Robertk is offline
2017 Rps hawk 250 red hot header help
I need help. I dont do much with the internet an took me an hour to figure out how to post on here............
But I have a 2017 hawk 250 with 190 miles on it.
I just installed..... mikuni vm26 with (120) jet, NGK iridum, full exhaust and did the air box mod.
When i start it up it only takes 20 seconds or so and the header gets CHERRY RED HOT. So i shut it off.
What is causing this?? I tried puting a 125 main jet in it and playing with the air/fuel screw, tried using the old spark plug, checked valve lash, ect ect....
Im afraid to run it long enough to get the air/fuel mix set so it will idle at lower rpms. (Pry 1500-200rpms now)
Is it super lean or does this exhaust pipe just get that hot cas its cheap and thin?
I dont want to drop a valve or anything
Old 08-05-2017, 01:51 AM   #2
BARLOW   BARLOW is offline
BARLOW's Avatar
sounds like the exhaust is clogged, or the timing is off ... i would not run it ... i run a 115/40 setup and it is rich, not lean ... i would start with the back half of the exhaust, because it is easy to get off of the bike, and you can run it without it, unlike the header ... but my best guess is the cat is going to be clogged/smashed inside ... if you or a buddy can weld good, i would cut the guts out of the cat asap anyway
Old 08-05-2017, 02:17 AM   #3
The exhaust is not clogged its the ebay race exhaust, not the factory exhaust
How do i check the timing?
Old 08-05-2017, 03:18 AM   #4
pete   pete is offline
pete's Avatar
Ok.... 20 seconds is pretty dam quick..
a bike will glow the header if it is sitting
idleing for a while..theres no airflow to cool it
both my bikes do it.. but it takes longer than 20
seconds..A lot longer..
do you have any idea what the wall thickness of the header is ?
stainless steel heats up alot faster/easyer than steel..
can't give you any jetting help... don't have a hawk .. anything would only be
second hand info you can find here..
But I assume it is doing it at idle... so if it is jetting it's most lightly to be the pilot jet..
also check for a air leak at the motor/exhaust join...
09 XT660R ...
06 TTR250 ...
80 Montesa H6 125 Enduro...
Current resto projects..
81 Honda CT110...
80 Kawasaki KL250A1...
http://www.remotemoto.com/
E-mail... xtpete1@gmail.com
Old 08-05-2017, 09:51 AM   #5
ben2go   ben2go is offline
Hot exhaust is caused by a lean condition or valves being out of adjustment.
Old 08-05-2017, 10:08 AM   #6
pistolclass's Avatar
Did it do this before the mods? If not, i' m suspect of the new exhaust or plug. Try putting some of the old stuff back on then mod 1 thing at a time.
Old 08-05-2017, 12:43 PM   #7
Valves adjusted correctly. I dont think it was hot before the mods. Im going to try modding the factory carb and see if it still does it
Old 08-05-2017, 04:05 PM   #8
If the new exhaust's tubing is thinner than the original exhaust, it will get hot faster.
Old 08-05-2017, 04:15 PM   #9
Well i took the mikuni off. and opened the factory carb up. Put a 120jet and 2 3/4 turns on the air/fuel needle also 2 washers under the main jet needle and put it on the bike. It now runs great. The problem was the mikuni vm26.
Old 08-05-2017, 05:58 PM   #10
What slot was the VM26 groove set to?
hawk, mod, tune, upgrade
