Old 07-16-2017, 02:07 PM   #1
Al   Al is offline
Change oil
How often after the first oil change should I change my oil? Every tank, 10 hours,. Looking for a ball park number. I am using Rotella 1540 oil.
Thanks
Old 07-16-2017, 02:12 PM   #2
Mudflap   Mudflap is offline
I've been changing mine every 20 to 30 hours on the CG engine but you didn't mention which engine you have. The owners manual that came with the Rhino says oil change every 160 hours which I think is way too long.
Old 07-16-2017, 10:12 PM   #3
Al   Al is offline
My manual says I have a 154fmi engine.
Old 07-17-2017, 07:42 AM   #4
Probably a horizontal Honda clone 125cc. In a quad these engines work hard and run hot. I'd go for 20 hours and check to see if the oil is looking dark. Run it longer if it still looks clean.
Old 08-14-2017, 08:49 PM   #5
Al   Al is offline
Did an oil change today. wow is it ever dirty!!!!! I used the rottela 15 40. I am going to try amsoil 10 40 see if I get better results. I was having the hardest time turning over the engine can't believe what a difference an oil change makes. It's like new again. Just waiting for a carb now
Old 08-15-2017, 04:52 AM   #6
pete   pete is offline
pete's Avatar
On the CT110 forum they say this stuff is the best for the horizontal motors
with a cast iron barrel...
====> http://dratv.com/ca10siqu.html
prob no better than any other motorcycle oil....
but yer never know anythings possable...
09 XT660R ...
06 TTR250 ...
80 Montesa H6 125 Enduro...
Current resto projects..
81 Honda CT110...
80 Kawasaki KL250A1...
http://www.remotemoto.com/
E-mail... xtpete1@gmail.com
