06-27-2017, 08:37 AM | #1 |
Front brake singing
Morning all,
This isn't a huge problem, I could totally live with it, just wondering if anyone has any tricks to stop it or quieten it. It might just be a characteristic of these pads. My front brake has started emitting a groan when slowing to a stop, like a freight car when the brakes are applied. I've had this in the wet on my other bikes, but my TT250 has started doing it. It's like the new Bonneville |
06-27-2017, 10:02 AM | #3 |
Try cleaning the rotor and pads with brake cleaner. I had the same happen to me a couple of weeks ago. They would make a grunting noise. Turned out that some were I must of ran through some oil on the road and got on the rotor and brake caliper. I cleaned them of and all good.
06-27-2017, 10:43 AM | #4 | |
06-27-2017, 01:40 PM | #6 |
Are you discussing a brake squeak or chatter?....or a hum?
As much as I like the stock tires for our riding purposes, they hum like crazy on pavement.
06-27-2017, 02:05 PM | #7 |
It's the brakes squeaking while coming to a stop. Well, more of a high pitched groan.
06-27-2017, 02:47 PM | #8 |
The sound coming from the brakes happens because of a effect similar to the effect of a bow rubbing the strings of a violin, to obtain that effect on a violin you have to apply wax on the bow, similar effect happens on the brake pads when they are glazed, that's why de-glazing the pads is the most effective way to stop the squealing, there are fluids on the market that help reduce that effect, but most are just lubricants which can reduce the braking efficiency.
06-27-2017, 03:38 PM | #9 |
Same thing happened to me after riding off-road a bunch. Went away after a while.
06-28-2017, 01:08 AM | #10 | |
Also check for rocks grit etc.
06-28-2017, 03:23 AM | #11 |
What grit do guys you use? Is it wet/dry grey for sanding cars because that is what I would use.
We need to specify the grit and type before people start pulling out the heavy grit.
06-28-2017, 04:23 AM | #12 | |
Ideally, the rotor surface should also be scuffed a bit to help the "new" pad surface bed in properly, but many people choose not to and it works ok. One way to go about this is to get a brake rotor Flex-Hone (more expensive than a new chinese bike brake rotor), but I have had good luck with simply scuffing the surface of the rotors with red scotch brite pads and a bit of elbow grease. Very non-aggressive way to give the rotor a bit of texture. Just make sure to clean both pads and rotors with brake cleaner and wipe them clean.
06-28-2017, 10:38 AM | #14 |
Great! That was an easy fix.
06-28-2017, 11:52 AM | #15 | |
No , did not use 80 grit good point Sully...nice. some of those little things can really annoy us.
