Old 05-05-2017, 10:43 AM   #1
prismways   prismways is offline
prismways's Avatar
Vader - installing short clutch
So I purchased this short clutch off the internet and I think it is like the RSC clutch.
I am noticing though that ourclutch has a wire connected to a little switch inside the clutch. Does anybody know what that switch is for? I noticed that when MAXIPADMOTO swapped his out with an RSC clutch lever, it also was missing the wire so he got rid of it.
Old 05-05-2017, 10:49 AM   #2
lildew   lildew is offline
you can take a male spade and see if that will bypass it those or connect so you can start the bike while in gear i am going to mess with mine tonight i can post what i did unless you get figured out before then.
Old 05-05-2017, 10:54 AM   #3
prismways's Avatar
Hmm. I have started my bike without the clutch on so not sure if this is related.
Will try and see how it goes.
thanks
Old 05-05-2017, 11:04 AM   #4
MOTOXtreme   MOTOXtreme is offline
thanks
You started it without the clutch in Neutral. If your in gear, You must depress the clutch, which closes the switch to allow the bike to start.
Brian
Previously owned / operated MOTO Xtreme selling American Lifan / Check out my friends at www.armattanquads.com
"Imagination is more important that knowledge" Albert Einstein
Old 05-05-2017, 12:34 PM   #5
prismways's Avatar
Got it. thanks for confirming.
Old 05-05-2017, 12:36 PM   #6
prismways's Avatar
Here is where I got it in case anybody is interested:
https://www.wish.com/search/clutch%2...50560bfb67bae4
be aware, it does remove your left mirror. I have purchased a replacement set.
Also, noticed I definitely will need to oil the joint.
Old 05-07-2017, 08:36 PM   #7
prismways's Avatar
So installed the clutch and it works great. I left the contacts unconnected so that the bike would only start in neutral.
I did have to play around with the adjustment knob and the screw, but it makes a big difference and I highly recommend it.
I also bought this to re-install the side mirror
https://www.wish.com/c/577497abdfab657851de1754
