Old 05-01-2017, 11:23 AM   #1
prismways   prismways is offline
prismways's Avatar
Poll - How fast does your 125cc go? (Vader / Razkull / etc)
So I'm curious, how fast are people pushing their 125cc motorcycle?
I have the Boom Vader with a Mikuni VM26 carb and cone filter and 125 jet.
I haven't pushed it past 43mph with it hovering around 6K RPM but I am noticing that the whole bike buzzes and vibrates so much, I'm wondering if it will fly apart into a hundred pieces. Is 6K RPM about right for cruising speed in 4th gear?
So when you reply, tell us the following:
Make / Model
carb upgrade?
airbox or cone filter
jet uprade?
Top speed
Max RPM
Does your bike feel like it will tear apart at the top speed?
what's your cruising speed and RPM?
Really interested to hear others' experience.
thanks
Old 05-01-2017, 12:06 PM   #2
Adjuster's Avatar
I don't have the bikes you're listing but I do have a Honda horizontal engine 125cc clone bike. It has a fully automatic transmission. It easily will do 45mph but gets loud and buzzy as you say. I think if it had a standard transmission with the right gearing it would go faster and be much smoother. I believe I am running the PZ19 carb with cone filter and I drilled out the exhaust to open it up some. Drilling out the exhaust made the biggest improvement in power/speed.
Old 05-01-2017, 01:16 PM   #3
prismways's Avatar
thanks for chiming in, that is good to know. Do you know what RPM you're at when doing 45pmh? What do you think your max is?
Old 05-01-2017, 01:56 PM   #4
Jrack   Jrack is offline
Check out (miami scooter club) on youtube. He really pushes his Vader. He has a stock carb, 90jet, air box mod, 17t sprocket and I think an AR exhaust. He commented his bike got to 63, although I'm sure he's gotten it faster since.
I have the Vader 125..
I have stock carb, pod filter and jets coming in the mail today. I took off the exhaust heat shield, drilled out the exhaust and installed a 16t front sprocket. I've pushed my bike to 7000 hit a max of 56 mph. Plan on ordering a piranha oil cooler kit off amazon later this week. I hope it works.
Make sure you check your front fender, when I got the bike I know I tightened it. Vibrated loose and had to re-tighten it. Mine vibrated so much it was uncomfortable to ride. Riding often or whenever I get the chance, the vibrations have gotten better. Also, my break light is just kind of floating...probably cause for a lot of the vibrating going on.
https://www.amazon.com/Piranha-Compl...oil+cooler+kit
Old 05-01-2017, 05:06 PM   #5
Skin Mechanic   Skin Mechanic is offline
Skin Mechanic's Avatar
Before you guys start throwing numbers around, test your speedo for accuracy. I did speed runs on my bike using 3 different GPS based speedo apps on my cell phone and my bike's speedometer is about 5mph optimistic. The speedo would read 59mph and I was really doing 54mph.
2017 Ice Bear Little Monster, work in progress
2007 Aprilia RSV1000R, unreliable piece of sh*t
2007 Moto Guzzi Breva V1100, epitome of reliability
2000 Moto Guzzi California V11, resting in pieces
The cage: 1998 BMW Z3, 1.9L w/full Dinan engine upgrades
Old 05-02-2017, 09:24 AM   #6
prismways's Avatar
Point taken. I'm not looking for anything scientific. Wondering what is the real "red line" on these things and how close I am to it. At 6KRPM and I'm only doing about 45MPH, is it safe to go to 8KRPM to get to a decent cruising speed without killing the motor?
Old 05-02-2017, 11:16 AM   #7
This is true. I've had to use a speedo app for my bike before I got a new sensor hub.. 1000 bikes 1000 variations
Old 05-02-2017, 06:30 PM   #8
jsumd   jsumd is offline
jsumd's Avatar
Completely stock vader about 48ish
2002 Harley Davidson XL883R
2012 Yamaha FZ6
2022 Hawk 250
2002 Yamaha R6 *sold*
Vader 125cc *sold after owning for many years*
1997 Jeep Wrangler *sold due to frame rot*
Old 05-02-2017, 07:18 PM   #9
When I took my bike on it's first ride I hit 60mph in a full tuck going down a small hill. A bone stock ankle nipper doing 60mph I knew I had to get out the cell phone and do a reality check. I've gotten the bike up to 56mph in a full tuck, on a level straight. The bike was doing 8200rpms with the 15t sprocket. I put a 108 link chain on it yesterday and installed a 16t sprocket. I was able to get up to 56mph@7100rpms on the way home from work today. I've gotta 17t sprocket on order, which will get me up to cruising speed at an even lower rpm, but I'm thinking 16t may be the best compromise between top end speed and off the line acceleration. With the 15t sprocket 1st gear was useless, I would start off in 2nd and give it a little more throttle before letting out the clutch. I can use 1st gear with the 16t sprocket, but under 30mph the acceleration is
Old 05-02-2017, 10:03 PM   #10
prismways's Avatar
That's interesting! I'm going to install the 16T sprocket. I agree, 1st gear right now is so useless on the 15T sprocket. I am willing to give up a little low end acceleration to have a lower RPMs at the high end cruising speed.
My bike is really starting to ride great and every time I take it out, it seems to get smoother. Today I was up to 50mph at around 7000RPM.
Old 05-04-2017, 12:21 PM   #11
Do any of yous guys have registration marks on your chain adjusters? Mine doesn't have them and I couldn't find my alignment tool. I had to use a machinist's rule to get the new chain in the ballpark until the new alignment tool arrived this morning.
Old 05-04-2017, 12:45 PM   #12
bogieboy's Avatar
i had a 110cc horizontal pocket bike that i hit 57 mph with... but that took some work...LOL stage 2 cam, vm26 carb, ported head, and a wide open exhaust.... was a wicked bike though...LOL
Old 05-04-2017, 01:02 PM   #13
prismways's Avatar
Nope, no markings whatsoever. Before I change my sprockets, I'm going to put in some markings on both sides.
Old 05-05-2017, 02:17 PM   #14
PhildoScaggins   PhildoScaggins is offline
I've just kinda eyeballed it... not the best idea but I have only hit 50 miles as of today. Still waiting on my MCO. Wondering if scratching or putting light markings in with a grinder is a bad idea or not.
Old 05-05-2017, 02:50 PM   #15
prismways's Avatar
hehe. yeah, the grinder might be overkill. I was thinking of a file or flathead screwdriver. lol.
