03-20-2017, 10:04 PM | #1 |
RIP wheel bearing
Finally got the bike running right today and took it for a ride, the rear wheel was wobbling and I stopped thinking the rim was bent. The rear bearing basically disintegrated.
I saw SeerAtlas's thread and read another with Pete, and concluded that you just have to pop out the old one and order what the 4-digit number and 1RS/2RS designation said, then swap them. Is that right? I took mine out, after a little bit of torch work, and it reads 6302 2RS and on the bottom it says CXCL. What do you guys suggest? What else should I do besides put in the new bearing? Thanks.
2015 Hawk 250 ~ Aftermarket Exhaust/K&N/LED everything/16/44T/Shinko 705's |
03-20-2017, 11:03 PM | #2 |
New bearings for me must be... "Made in Japan"... and I always pop the seals before installing them to make sure enough grease is packed in them from the factory... then I enjoy many years/miles of trouble free driving/riding
03-21-2017, 12:11 AM | #3 |
CXCL is 10000% rubbish. CXCL http://www.cxcl-bearing.com/aboutus/...tentId=10.html = Tech support by KOTO (some doggy paper co. http://www.searchtmr.com/details?trq...22f08&hl=en_US)
Product from http://www.cugroup.com/ is good enough for that job. 1 of the OKish chinese brand... === I prefer a Swedish brand that started w/ S http://www.skf.com/binary/92-179206/...ls_6270-EN.pdf
03-21-2017, 01:33 AM | #4 | |
I never put more grease in the bearing as I want it to last... not have to much drag from the grease making to balls/rollers skid around the races instead of rolling... How meany tests & $ went into working out how much grease should be in a bearing.. ...
09 XT660R ... 06 TTR250 ... 80 Montesa H6 125 Enduro... 77 Montesa Cota 348 MRR "Malcom Rathnell Replica"... Current resto projects.. 81 Honda CT110... 80 Kawasaki KL250A1... 11 Husaburg TE125 enduro... "sold" along with another 31... Lifan 125 Pitbike.. "stolen" ... KIWI BIKER FORUM...... http://www.kiwibiker.co.nz/forums/content.php All the best offroad rides in NZ... http://www.remotemoto.com/ E-mail... xtpete1@gmail.com Last edited by pete; 03-21-2017 at 02:15 AM. |
03-21-2017, 08:26 AM | #6 | |
03-21-2017, 09:08 AM | #7 | |
I've seen all kinds of bearings... "FAG" and "SKF" bearings included... be delivered with barely any (read... almost NO) grease inside the thing... reason I pop the seals and check/clean/repack with the proper amount of grease... I also like to use a "Marine" grade grease on my motos... But hey... "to each their own" right?
03-21-2017, 09:12 AM | #8 | |
03-21-2017, 09:51 AM | #9 |
Jet, those seen lots of water? Deep streams or pressure washing?
03-21-2017, 11:04 AM | #10 |
You know, I have no idea, in my ownership..no, but I did almost get stuck in what I thought was a dry lake bed, so mud..clay....water, but that was once. That's the only time she's really seen elements besides some trails and road riding... Now the last owner, that's a different story. He was from what I could tell, very negligent with her, considering all the things I've had to change and fix on the hawk.
Do you guys think I should replace the front wheel bearings too? I mean this little incident has me worried considering the bike only has about 4k miles. I would just hate to be taken out by a chinese bearing ha ha SKF?? http://www.ebay.com/itm/SKF-6302-2RS...gAAOSwoudW9Jrj
03-21-2017, 11:15 AM | #11 | |
03-21-2017, 11:49 AM | #12 | |
So just SKF or FAG brand?
03-21-2017, 11:58 AM | #13 |
Either would be fine. I've used others with no problems.
03-21-2017, 12:05 PM | #14 |
I watched some videos on how to install them, do you guys recommend a press tool? I need to grease the outside/inside the bearing (not the ball bearings), but what about the spacer or axle?
Thanks for all the replys
03-21-2017, 12:21 PM | #15 | |
Grease the axle and other parts. It help keep water out and will make removal much easier next time.
