Old 03-10-2017, 09:47 AM   #1
mdyates   mdyates is offline
Chain for Hawk 250 question
Just ordered a 428 122 link as I installed a 40T rear (front stock) and 130 link wayyyy to long. Couple questions. I cannot find a connecting link on stock chain? New chain ok choice?
Old 03-10-2017, 10:05 AM   #2
Ariel Red Hunter's Avatar
Yes, that's a good chain. Much better than the one that comes from the factory. Uni-Bear is another very good chain. A lot of guys are using that chain and I've never heard a bad word said about it....ARH
Old 03-10-2017, 12:30 PM   #3
hertz9753's Avatar
You should buy a chain breaker and a master link. I will admit that I have never seen a motorcycle chain that didn't have a master link.
Old 03-10-2017, 02:14 PM   #4
jet321   jet321 is offline
I would recommend this as well, I followed motocheez's video and used vice grips with a dremel grinding tool, it was the longest 1.5 hours to get a chain on I've ever experienced, my thumbs will never forgive me
2015 Hawk 250 ~ Aftermarket Exhaust/K&N/LED everything/16/44T/Shinko 705's
Old 03-10-2017, 02:35 PM   #5
Most factory chains don't come with master links. On the assembly lines, they have bins with pre-cut lengths of chain, and then the last step in the driveline assembly is to rivet in the last link. The 5 seconds it takes to use the pneumatic riveter and a steel pin is much cheaper than supplying each bike with a master link. Kind of like a few years back when some bean-counter at Delta discovered they could save millions of dollars a year in costs if they put one less crouton on their in-flight salads...
First Rule of Aviation:
The Stable:
2005 Yamaha V-Star 650 - SOLD
2015 Suzuki DR 650
2015 RPS Hawk 250 - SOLD
2016 Ural Gear Up
Old 03-10-2017, 03:21 PM   #6
pistolclass's Avatar
Hey easy on the bean counters
Old 03-10-2017, 04:32 PM   #7
And I thought I was going crazy! Thanks for info
Old 03-10-2017, 07:39 PM   #8
my 2016 hawk has a master link
2016 hawk
kaw h1 400 tripple
13' long chopper in progress
2009 johnny pag bar hog
Old 03-10-2017, 07:54 PM   #9
Same here
2020 Kawasaki Vulcan S
2004 Honda ST 1300
Old 03-10-2017, 07:59 PM   #10
Rail32   Rail32 is offline
Rail32's Avatar
Master link on my 2017 . I am not happy about the stretch in mine already at 200 miles mostly off-road . Will be replacing by spring I am sure .
Living life to the fullest to avoid regrets later ,,,,or I am a complete loon ! Either way I am good
Old 03-10-2017, 08:20 PM   #11
These bikes don't come with very high quality chains. I reccomend you google up Uni-Bear chains, and get the 428H chain. A lot of guys have been running that chain with no complaints. It comes pre-streched from the factory, and each link is staked four ways....ARH
Old 03-11-2017, 05:26 AM   #12
My Hawk came with a master link as well. I was pointing out that most bikes nowadays do not. My DR650 did not, the Missus' TU-250X didn't, and I don't think the Rebel did, either. My boss down in Florida has an R1, and that didn't come with a master link, either. I don't think very many sportbikes have master links because of the dynamics of the chain spinning as fast as it does. Something about the clip flying off at ludicrous speed and the chain doing a lot of damage as it unwinds from the sprockets. Not really something that would be a concern on a CB.
The Stable:
2015 Suzuki DR 650
2016 Ural Gear Up
Old 03-11-2017, 05:59 AM   #13
chuck   chuck is offline
400 miles on a uni bear and no stretching,it's a great affordable chain.
Old 03-11-2017, 07:43 AM   #14
Rail32's Avatar
Agreed and I guess I needed a chain breaker years ago anyways
My first bike with no clip was KLR . I bet I looked for half an hour before I dug out thin wheel on grinder
Old 03-11-2017, 07:44 AM   #15
Rail32's Avatar
I am on it
