Old 01-26-2017, 09:03 PM   #1
Riderx   Riderx is offline
New Hawk owner in Pearland, Texas. Glasspack exhaust etc...
A fun new toy with upgrades that don't break the bank. Top speed 66mph.
Old 01-26-2017, 09:08 PM   #2
Sport Rider's Avatar
welcome to the forum. did you tear out the cat in the exhaust?
Old 01-26-2017, 09:23 PM   #3
Good question. Where is the cat located?
Old 01-26-2017, 09:30 PM   #4
bulge in pipe under the heat shield near the motor.
Old 01-26-2017, 10:10 PM   #5
Thankyou. I have a new project to remove it. Probably cut it out with sawsall or cutoff wheel and jb weld pipe back togethether.
Old 01-27-2017, 07:38 AM   #6
Once you gut the cat you could always bring it to a muffler shop and have them weld it up if you don't have access to a welder. I'm not sure JB weld will hold up with the vibration from the motor. But at the same time I would be curious to see how weld the JB weld would hold up.
2020 Kawasaki Vulcan S
2004 Honda ST 1300
Old 01-27-2017, 09:06 AM   #7
Good idea for muffler shop. Thanks
Old 01-27-2017, 09:12 PM   #8
jct842   jct842 is offline
jb weld will melt at the high temp of exhaust.
Old 01-29-2017, 07:59 PM   #9
Catgut complete and removed the exhaust clamp. I bought a $100, 90 amp welder from harbor freight and did the welds myself. The welds are'nt pretty but fuctional with no leaks.
Old 01-29-2017, 08:38 PM   #10
Customx253   Customx253 is offline
Catgut complete.
Which pod filter you running for the carb and engine breather. I may have melted my airbox today...
Old 01-30-2017, 11:32 AM   #11
You'll need a pod with a 42mm ID. This is my favourite for dusty areas: http://www.ebay.com/itm/BLACK-42mm-B...9X0l39&vxp=mtr
Old 01-30-2017, 12:01 PM   #12
Uni brand air filter 42mm and crankcase vent 1/2" pipe fitting. I removed stock airbox, cat and and stock muffler and slipped on a 23" glasspack.
Old 01-30-2017, 02:09 PM   #13
did you replace the air box with some type of plastic guard so that you're not slinging mud back up in there? That's the primary reason I left mine.
Old 01-30-2017, 02:12 PM   #14
what welder did you get and how did it do for you? I'm wanting to get one. a long time ago I had a cheap stick welder which did not work out so well due to limited power. it didn't seem to want to properly melt the two ends of metal for a good bond. (this coming from a VERY rank amateur!)
Old 01-30-2017, 07:44 PM   #15
To prevent debri from rear wheel I fabricated sheet metal guard. See pic:
I purchased the flux core wire feed welder. Works well for the price and my welding inexperience.
