09-13-2016, 02:12 PM | #1 |
Valve Check #6
You all are probably tired of reading about my valve checks.
I know I'm tired of doing them. The bright side was that both the intake and exhaust valve clearances were still at .003" after 2,000 miles....... The angled feeler gauge helps to make the job marginally less aggravating. I use the same one on the DR650 Available from CSC: http://www.cscmotorcycles.com/FEELER...ps57-80526.htm As an aside....you know that the valve covers can be installed upside down. When it's late and you're tired, this can happen: How do you know? The skidplate is covered with oil, along with various other parts of the engine: jb
2016 Honda CB500F......2017 Triumph Street Twin 2014 XT 250........ Last edited by jbfla; 09-14-2016 at 02:08 PM. |
09-13-2016, 05:36 PM | #2 |
Good tip jbfla, but sorry that happened to you. My next valve check, I'll be marking mine too, just to be sure.
09-14-2016, 06:54 AM | #3 |
your not alone i did the same thing i marked in. and ex. but installed ex. upside down now have it all marked
Peace and Zong Life
09-14-2016, 02:14 PM | #4 |
I had to edit the original post because I had mistakenly posted that the valve clearances were set at .03 inch.....
Corrected it to read .003 in. (three thousandths of an inch) As I had to remove the spark plug anyway, I decided to replace it with an NGK iridium spark plug. jb
2016 Honda CB500F......2017 Triumph Street Twin 2014 XT 250........ |
09-14-2016, 05:39 PM | #5 | |
Always one of my first "upgrades" is getting rid of those nasty older than dirt Copper Plugs Have you noticed any changes in idle/performance/mpg? Let me know, as I always like to hear peoples results and what they "notice"
09-14-2016, 05:54 PM | #6 | |
As I have stated before, the engine of my RX3 has run great from the day of delivery. It starts on the first push of the starter button, and purrs throughout the rpm range. Even when I had the problem with the cam, you wouldn't know it by the way the engine ran. jb
