08-08-2016, 10:53 AM | #1 |
nibbi carb
does anyone have any experience with this carb https://www.amazon.com/dp/B01CYKGO9Y?psc=1
it looks to be of great quality and easy to jet would it fit a zongshen 250? any other carb suggestions if this isnt worth it? |
08-08-2016, 11:04 AM | #2 |
That does look like a really nice setup! Nice machine work. I have that same Nibbi air filter and am very happy with the quality. Flat slides are supposed to be good, not sure why though. It says flat slide but it looks round???
My only concern is it's rather spendy. You can get a Mikuni and that air filter for less than half the cost and they work very well...and jetting is abundant. Any idea where to get jets and for what model carb? Edit: Ok...I see some of the kits come with 4 jets.
08-08-2016, 12:19 PM | #3 | |
08-08-2016, 12:35 PM | #4 |
That's definitely a round slide, and it appears to be a two-stroke carb. It has an air screw rather than a fuel screw, and it's on the wrong end of the carb.
08-08-2016, 12:41 PM | #5 |
yeah i saw that but it doesnt have enough review not sure if a fluke or not and looking at other sites and reviews people seem to like it just a little pricy i just want a carb that isnt to hard to jet since in my state between summer and late fall ill need jets from 105-115 likely
08-08-2016, 11:41 PM | #6 |
Nibbi is suppose to be good I don't have any hands on experience with them as I typically opt for Keihin or Mikuni. I don't believe Nibbi does any real R&D all though some say they do just like OKO and KOSO. I seen a PE 28 listed as semi flat side (half moon) though it defiantly does not look like a flat side. Not sure if it's true. I've seen some PE series described as "4 stroke special" but have no idea if this is true or not. The listing does say CG so you might be okay. Worse case they ship you a 2 stroke carb.
If it is in fact a 4 stoke carb it's probably a Frankenstein so parts and jets maybe difficult to find from anyone else but Nibbi. Although I would suspect it would be part Keihin PE and PZ. http://www.keihincarbs.com/carbs/pe/gate.html Here is a PE28 clone for reference http://www.ebay.com/itm/252336767414 Last edited by nonone; 08-09-2016 at 12:24 AM. |
08-09-2016, 02:48 AM | #7 |
Get a Koso flat slide carb call it a nibbi put a few bling bits on it
and add $60 to the prise...... why not go to alliexspess and buy the un-blinged version for a 1/3 of the prise.. I imagine they are pulling the same with the round slide in your link... I have a OKO flat slide 26mm on my 1977 Montesa cota 348 trials bike & a Koso 32mm flat slide on my Yamaha TTR250.. the "flat slide" is in fact a D slide...best of a round & flat slide... Main and Pilot jets are on alliexspress for 10 jets of your choice for around $10 per 10.... 32mm KOSO D slide power jet on my Yamaha TTR250... they work well.... ..
09 XT660R ... 06 TTR250 ... 80 Montesa H6 125 Enduro... 77 Montesa Cota 348 MRR "Malcom Rathnell Replica"... Current resto projects.. 81 Honda CT110... 80 Kawasaki KL250A1... 11 Husaburg TE125 enduro... "sold" along with another 31... Lifan 125 Pitbike.. "stolen" ... KIWI BIKER FORUM...... http://www.kiwibiker.co.nz/forums/content.php All the best offroad rides in NZ... http://www.remotemoto.com/ E-mail... xtpete1@gmail.com Last edited by pete; 08-09-2016 at 03:41 AM. |
08-09-2016, 06:57 AM | #8 | |
08-09-2016, 11:54 AM | #9 |
I'm having a heck of a time locating a replacement idle mixture screw for my VM 26 knockoff. Everything else is no problem though.
08-09-2016, 02:59 PM | #10 |
I found one for a Mikuni vm 26 on e-bay. Item number 191539860297.
08-09-2016, 04:57 PM | #11 |
no, that's an idle screw, not idle mixture.
08-09-2016, 08:17 PM | #13 |
Are you looking for the Air Screw? Part # VM20/214.
www.ebay.com/itm/172119470734 Or one of the variations there quite possibly could be others http://www.aliexpress.com/store/product/Free-shipping-2PCS-fuel-ratio-adjusting-screw-Motorcycle-carburetor-Mikuni-the-carb-air-screw-For/1540211_32597630286.html http://www.aliexpress.com/store/prod...633161488.html At ~$10 your better off buying another carb like Bruce said. Extra parts always come in handy. Here is some good info for VM's http://www.vintagesnow.com/Carbureto...s/vmmanual.pdf |
08-09-2016, 10:33 PM | #15 |
and forgot to add wold need jetting too prob between 105-115 ive read they come super out of tune with jets that are much higher then they should be. anyone have any experience with these is this true?
