Old 07-26-2016, 05:27 PM   #1
kd2dxf   kd2dxf is offline
Hawk Muffler issue
This is about the 3rd time I have lost one or both bolts off the engine exhaust manifold. I plan on getting grade 8 lock nuts this time. However I cant remember what size Nut/Bolt for the Exhaust flange. Looks like a 10MM?
Old 07-26-2016, 07:48 PM   #2
pcspecialist   pcspecialist is offline
Double nut it
Old 07-26-2016, 08:26 PM   #3
I ended up putting split lock washers with lock nuts. Hopefully that will fix it
Old 07-26-2016, 08:55 PM   #4
hertz9753's Avatar
I use stainless flat and lock washers on my exhaust header.
Old 07-27-2016, 11:47 AM   #5
Ariel Red Hunter's Avatar
Most lock nuts have nylon locks. They can't take the heat of an exhaust head pipe. Either double nut them or safety wire them.
Old 07-27-2016, 02:33 PM   #6
Anyone know why I would feel grinding/vibration when decelerating? dont know any other way to describe it. I tightened the chain thinking it was that, but I still feel it. maybe time for new sprockets?
Old 07-27-2016, 03:21 PM   #7
new grinding issue
So I took a look at the chain, and sprockets. brand new DID HD Chain. sprockets have no/little wear.
Ill also point out that when i pull in the clutch and coast, the grinding feeling goes away
Old 07-28-2016, 01:56 AM   #8
pete   pete is offline
pete's Avatar
most common garden type are .. but not all.....
use cone lock nuts... no nylon insert.....
exhaust nuts are usaly 8x1.25mm
09 XT660R ...
06 TTR250 ...
80 Montesa H6 125 Enduro...
Current resto projects..
81 Honda CT110...
80 Kawasaki KL250A1...
http://www.remotemoto.com/
E-mail... xtpete1@gmail.com
