Old 07-14-2016, 10:00 PM   #1
b44   b44 is offline
Engine knock sound, thoughts?
Seems like in hogging this forum so bear with me
Zong is making engine knocking sound, its a lot quieter now so this sound is very exaggerated, but still a definite knock there,
She starts/idles/rides fine its when in idle you hear this , and low-medium revs
Im suspecting timing?
Running boosted fuel
Video was piston was new fyi
Old 07-15-2016, 12:12 AM   #2
Adjuster's Avatar
rpm way low
one of your adjuster nuts fell off the valve
exhaust leak
Old 07-18-2016, 11:38 PM   #3
Mag00   Mag00 is offline
Try putting your hand over the exhaust and pay attention to how the noise changes. If it is exhaust leak, the sound should change.
Pull the clutch lever and see if it changes.
Check the valve clearances.
Bashan 250 Storm
Husqvarna TR650
Honda Metropolitan
Be a Piggy!
Old 07-25-2016, 05:29 AM   #4
b44   b44 is offline
Ok this is video taken today, you can hear knock/rattle every 2-3 seconds exhaust sounds are gone its got a kind of possible tapping sounds
Appreciate the help fellas
Old 07-25-2016, 11:19 AM   #5
Azhule   Azhule is offline
I'm thinking along the lines of the other 2 folks, did you ever check the valves yet or maybe you did what everyone here has done at least once before... set the valves on the wrong stroke/T line?
It makes a really loud "Tappy Tappy Tappy" sound when you do the valves on the wrong T-line
Old 07-26-2016, 09:47 PM   #6
b44   b44 is offline
Yes double checked valves, no change in blocking exhaust off,clutch in no change either, i raised idle speed has quieter noise still there on rev up ,think ill have to look at timing? Not sure if i should advance or retard, im thinking retard
Old 07-27-2016, 01:55 AM   #7
'16 TT250   '16 TT250 is offline
What is boosted fuel?
Old 07-27-2016, 09:32 AM   #8
b44   b44 is offline
Octane booster, for detonation
