Old 05-28-2016, 10:21 AM   #1
kornleash   kornleash is offline
2006 LFGY-5 200. Needs a new clutch.
Hello and thank you for viewing my post. I bought a used lifan 200 off Craigslist. For the first few days it rode okay but the clutch was "odd" I've had many bikes before this. And it just felt different. I figured maybe it is just the China bike feel. But today I was riding in the woods behind my house and I stopped to hop over a small log. When I went to dump the clutch a little to pop the front wheel over it it just revved and didn't go. Pushed it home and started tearing her apart. I've done clutches before but on v twins. So I split the case and the clutch looks fine. Smells a bit burnt though. Put It back together with new valvoline motorcycle 10w-40. With the chain off I can put it in neutral. Stop the front sprocket and shift into first and I can't stop the sprocket in gear. The sprocket speeds up with the throttle like it should. Put the chain on and put it in first and it doesn't go anywhere. Just revs up. I am thinking I need a new clutch. Any opinions? Ive adjusted the clutch cable all the way in and out. No change. Sorry for the long post. Any input is appreciated. Thanks again.
Old 05-28-2016, 09:33 PM   #2
humanbeing's Avatar
ohc (CB) or ohv (CG)?
Depends how it wear... U need some of these https://shop112956451.taobao.com/cat...1025258192.htm (Fraction plate or Whole assembly...) | Tips about vertical (c)honda http://www.mychinamoto.com/forums/sh...ink-Legend-250
Old 05-29-2016, 09:55 PM   #3
It almost sounds like a cable issue. Have you lubed and adjusted the cable?
Old 02-03-2017, 08:45 AM   #4
nathan93   nathan93 is offline
I know this thread is probabbly dead but does anyone know where to get a clutch for an 07 lifan grx-200?
Old 02-03-2017, 12:47 PM   #5
wilserchinarider   wilserchinarider is offline
Bunch of options on Ebay....not exactly sure what you are looking for but I bet it's there...
http://www.ebay.com/itm/Clutch-Assem...kAAOSw-yxU27yA
http://www.ebay.com/itm/Engine-Clutc...xWXFbw&vxp=mtr
I searched "200cc CG clutch"
Old 02-04-2017, 09:00 PM   #6
ben2go   ben2go is offline
Someone has been using automotive oils in the engine and now the clutch slips.
Old 02-04-2017, 09:38 PM   #7
Worse comes to worse, you could try the newly revived American Lifan
http://americanlifan.com/
200, gy-5, lifan
