Old 05-11-2016, 03:22 PM   #1
Swollbraham   Swollbraham is offline
Swollbraham's Avatar
Oil Housing Assembly(Hawk)
I did some searching before posting this, could not find what i need.
As i was changing my oil on the hawk. I realized there is no spring in the housing. im Assuming it was assembled without one installed. With out the spring there is no filtration of the oil. (this doesn't startle me just yet because it has clean oil and only has about 90 miles on it) but can anyone tell me where i can get a new spring? or the size of the original spring?
Old 05-12-2016, 12:37 AM   #2
Just so I'm sure, there was no spring under the strainer cap? That's a new one.
The spring for a Honda XR200 should be a perfect match, as long as it's '81-'83 or '86 on. The '84-'85 models were OHC, and possibly used different strainer springs. You can probably find a replacement at www.rockymountainatvmc.com or www.bikebandit.com
Old 05-12-2016, 12:38 AM   #3
BTW, while you're ordering the spring, order a new cap to keep on hand. Cracking one with no replacement will ruin your day.
Old 05-12-2016, 01:05 AM   #4
pcspecialist   pcspecialist is offline
Does anyone make magnetic caps and magnetic drain plugs for it?
Old 05-12-2016, 07:25 AM   #5
Correct no spring under strainer cap.
Rocky Mountain atv is like an hour away from me I called them they said they don't have a part number for the hawk spring. I thought about trying to guess by size, but have no idea what kind of pressure it needs on the filter itself. Thanks for the heads up about the extra cap. I can try to see if the Honda spring fits I'll update when I find out.
Old 05-12-2016, 07:25 AM   #6
Ive never seen any but that's a good idea.
Old 05-12-2016, 10:14 AM   #7
No, because the cap is aluminum. That said, you could epoxy a small rare earth magnet under the cap.
Old 05-12-2016, 10:32 AM   #8
Prima uses an aluminum cap milled a little different than stock to hold a magnet.
Old 05-12-2016, 10:48 AM   #9
That's cool. Most of the Hondoids only use the cap and strainer as an oil drain, and do not have a drain plug, per se. Typically, China ATV's that use a Hondoid vertical motor will have a drain plug, so they could use a magnetic bolt.
A strainer cap with a magnet would be cheap insurance.
Old 05-12-2016, 11:22 AM   #10
The kit is for a Chinese GY6 scooter. Magnetic drain plugs for both engine and gearbox and of course the strainer cap.
Old 05-12-2016, 12:26 PM   #11
Here is a photo of my first oil change. Lifan engine hope it helps
Old 05-12-2016, 12:40 PM   #12
Attachment 5829
I know its a long shot.
But do you by chance have a measurement on that spring?
Old 05-12-2016, 12:52 PM   #13
Negative sir and not due for another change yet. That pic was just a contribution so at least you can visulize. I sure the pressure won't matter it's just there to secure that strainer. Heck it looks about like a waterhose strainer to me.
Old 05-12-2016, 01:00 PM   #14
No big deal, i bought a big bag of random springs going to spend some time guessing tonight haha. thanks anyways.
Old 05-16-2016, 10:58 AM   #15
http://www.ebay.ca/itm/Honda-15426-1...-/301620837443
filter, hawk, oil, spring
