Old 04-11-2016, 04:09 AM   #1
Warning: Fractured Wheel Bearing
Several days ago I replaced the Shinko 244 tire on my rear wheel. I always inspect every part of the wheel every time I remove a wheel, or replace a tire. The rear hub has two bearings, and the bearing near the rear sprocket was completely fractured. I needed to cut the outer race of the fractured bearing with my dremel tool in order to remove it from the hub.
The bearing on the other side, near the brake rotor, was notchy, and ready to fail. I replaced both Chinese bearings with Japanese bearings, which I had in stock for the original hub of my Zongshen ZS200GY-2. The bearing in the sprocket carrier was in good condition.
The stock bearings have very little grease in them. I packed the new Japanese bearings with extra grease before I installed them. I have ridden over 13,000 miles on my RX3. However, I encourage everyone to check the wheel bearings, no matter how low your mileage. It is much easier to punch out a wheel bearing before it fractures.
I will post photographs of both Chinese bearings tomorrow.
Old 04-11-2016, 05:53 AM   #2
Juanro   Juanro is offline
Juanro's Avatar
Spud, please post bearing size or code, thanks
Old 04-11-2016, 06:03 AM   #3
Post Edited to Correct Errors
Since you are in Argentina, you might have an earlier version of the rear hub. It contains the following bearings.
Rear Hub Bearing Sizes
Rear Hub Bearing, Sprocket Side: 6202 2RS
Rear Hub Bearing, Brake Rotor Side: 6302 2RS
Sprocket Carrier Bearing: 6004 2RS
However, CSC, Cyclone RX3 motorcycles sold in the United States contain the following bearings.
Rear Hub Bearing, Sprocket Side: Two 6202 2RS Bearings
Rear Hub Bearing, Brake Rotor Side: Two 6302 2RS Bearings
Old 04-11-2016, 07:19 AM   #4
If you replace a worn bearing before it fractures, you can easily remove it. I prefer to drive out wheel bearings using a Motion Pro bearing driver and split collet. The bearings in the rear wheel of the RX3 can be removed using the following parts.
http://www.motionpro.com/motorcycle/partno/08-0260/
http://www.motionpro.com/motorcycle/partno/08-0268/
Just in case someone hasn't used this method to remove wheel bearings, here's how it works.
Old 04-11-2016, 07:26 AM   #5
I have bought individual drivers and split collets for the different sizes of wheel bearings in all my motorcycles. However, if I were buying the bearing drivers today, I would get the Pit Posse Motorcycle Wheel Bearing Remover Kit, PP-1692.
http://www.amazon.com/Pit-Posse-Moto.../dp/B005SUVQUK
http://www.ebay.com/itm/Motorcycle-W...ZyimIg&vxp=mtr
Old 04-11-2016, 08:01 AM   #6
You can decipher the bearing code by reading the information at the following links.
http://www.gizmology.net/bearings.htm
http://www.mymachineinfo.com/2015/07...ion-guide.html
http://www.engineerstudent.co.uk/bea...explained.html
http://www.engineerstudent.co.uk/bea...plained_2.html
For example, a 6202 2RS bearing has the following features.
6 = Deep Groove Ball Bearing (Single row)
2 = Light Duty Bearing
02 = Inner Race Diameter of 15 mm
2RS = 2 Rubber Seals
Old 04-11-2016, 08:17 AM   #7
Wheel bearings fail more quickly when they lack sufficient grease, and every wheel bearing I have examined suffers from this deficit. For example, here is a new wheel bearing I was going to install in one of my Honda motorcycles.
Therefore, I always pry off both rubber seals, and add more grease to the wheel bearing before I install it.
Old 04-11-2016, 08:20 AM   #8
Using a bearing driver makes it much easier to remove old bearings.
Just make sure you get the correct size driver and collet for the bearings you wish to remove.
Old 04-11-2016, 09:03 AM   #9
Juanro's Avatar
Very complete information, thanks!
I use my own method to remove bearings, paraphrasing Homer Simpson, there's the right method (yours), the wrong method, and mine, it's like the wrong but slower and with lots of swearing!
Old 04-11-2016, 10:40 AM   #10
Lee R   Lee R is offline
Lee R's Avatar
Thanks for the warning Spud. I'll replace mine on the first tire change as a precaution. I ride in lots of mud and water so the bearings probably won't last.
Old 04-11-2016, 10:47 AM   #11
Juanro's Avatar
Lee, I do also, my bearings have 16K km on them and they're smooth as silk, but as you said it's cheap insurance to change them anyway.
Old 04-11-2016, 10:54 AM   #12
Juanro's Avatar
Is this info on the sticky thread about parts? I was about to ask about front bearings also.
Old 04-11-2016, 11:15 AM   #13
dpl096   dpl096 is offline
dpl096's Avatar
Thumbs Up great write up
This is why this place rocks! Did you put the rubber seals back on afterwards ?
Thanx Spud
Old 04-11-2016, 11:27 AM   #14
Old 04-11-2016, 11:59 AM   #15
Azhule   Azhule is offline
Anchor Bolts and a slide hammer (or a anchor bolt, hammer, and punch combo) can also be used to remove Old Wheel Bearings and they only cost about $1 or so for the size of bearings our bikes use
