Old 04-05-2016, 09:44 AM   #1
traygiddens   traygiddens is offline
Checking/replacing fork oil hawk
Forks are not something i've really messed with before so some guidance would be helpful.
I want to check/replace the fork oil in the hawk. I'm guessing the same process would apply for the Bashan or other bikes on here.
Does anyone have some links in the forum regarding the steps on how to do this or other helpful links to videos for these china bikes specifically?
Special tools or equipment needed? special fluid?
Old 04-05-2016, 09:56 AM   #2
I think your Hawk has conventional forks. However, here is a link to a thread about changing the fork oil for USD forks.
http://www.chinariders.net/showthread.php?t=10266
Old 04-05-2016, 12:54 PM   #3
mq1991   mq1991 is offline
I was also hesitant to try this, but it turned out to be very easy.
-Undo the fork caps up by the triple tree
-Place a catch pan under the fork you are about to open
-Use a hex drive to remove the bolt at the bottom of the fork (Will be tight!)
-Let all the fluid drain into the pan
-Replace the hex bolt at the bottom of the fork and tighten
-Fill with (~150ml? I did 160ml and it seems to work great) of fork oil. I used this stuff
http://www.ebay.com/itm/231115859333...%3AMEBIDX%3AIT
1 bottle was enough to do both forks. I measured 150ml of water in a measuring cup, then poured that into a cheap plastic cup and made a mark where it filled to. I dried the cup and then filled to the same mark with the fork oil in the cheap plastic cup.
-Repeat on the other fork
Hope that helps! Post up any troubles you have along the way. Be sure to use the correct size hex key, if you strip that fastener it would be extremely difficult to get it out.
Good luck!
Old 04-05-2016, 05:37 PM   #4
TXDSRIDER   TXDSRIDER is offline
TXDSRIDER's Avatar
Good luck!
Yep it's pretty basic. Just be prepared that when the fluid drains out of the second shock the forks will drop to the ground if you don't support them.
Brandon
2014 Hawk 250
Firehawk minibike
Previous bikes~
1995 Yamaha YZ125
1998 Yamaha YZ250
1981 Yamaha YZ465
1987 Honda TRX 250R X2 one stock one modified
2002 Buell Blast
2001 Buell X1 Lightning
2000 Kawasaki ZR7
Old 04-05-2016, 07:18 PM   #5
Awesome information, thank you all.
