02-22-2016, 07:24 PM | #1 |
new spark plug
before you all line up to shoot me, i have used the search box, and did a lot of reading before posting this bot have not found what i was needing, even though i know it is already here somewhere ... so here it goes ... i have the 2015 bashan storm 250 and would like to know what number the ngk spark plug is so i can get a new plug
02-22-2016, 08:11 PM | #2 |
I run an NGK B8EA in my Hondoids.
02-22-2016, 08:16 PM | #3 |
thank you ... is that for the 229cc ... sorry, i am new to chinese bikes
i dont seem to be able to locate that number of plug |
02-22-2016, 08:55 PM | #4 |
when i was setting up my new bs250gy-31 bike i noticed that it was equipped with A ngk D8EA. they do run great on these ngk's. (engine tag model is lifan 167fmm) yes, it's a 229cc i believe. Hope this helps.
02-22-2016, 08:59 PM | #5 |
Wow! Could have been a critical Type-o! Thanks! D8EA! Holy cow, the D and B aren't even close to each other for a three finger typist either....
02-22-2016, 09:00 PM | #6 | |
http://www.chinariders.net/showthread.php?t=14251 | http://www.sparkplug-crossreference.com
02-22-2016, 11:32 PM | #7 |
ok, thank you ... the book that was sent with my bike was outdated, does not even have the counterbalanced motor in it, and shows cable operated drum brakes
02-23-2016, 08:06 AM | #8 |
Welcome to China Bikes.... ;-)
02-23-2016, 11:46 AM | #9 |
If you pull the spark plug and tell me what it has in it right now I can find a good replacement for you (or anyone that needs help finding one). I have done plenty of spark plug cross-reference/Iridium upgrades over the years, so put my little bit of exp to use if you like
As posted above, "spark plug cross reference" website is good, but you have to sometimes click around a bit to find the best brand that will fit
02-27-2016, 11:31 PM | #10 | |
when i took it out, i found that it had a ngk in it from the factory ... another nice upgrade ... i tried to read it in the head, but the ngk was on the other side |
02-28-2016, 05:46 AM | #11 |
Not all NGK plugs are equal. The Chinese made NGK that was factory installed in my Lifan 200 failed in the middle of nowhere when the center electrode moved up into the insulator, increasing the gap to the point where it was difficult to start and wouldn't idle. If your plug is a Chinese NGK I recommend replacing it with a Japanese NGK or at least carrying a spare.
02-28-2016, 06:28 AM | #12 |
I too would suggest 'upgrading' to a spark plug of known origin wont cost that much like a couple bucks to what... $10 if you got an Iridium from Denso or NGK
02-28-2016, 11:46 AM | #13 |
X3; the Chinese make counterfeit NGK spark plugs. You can buy a genuine, NGK, D8EA spark plug from the local, auto parts store for about $2.
02-28-2016, 11:54 AM | #14 |
ok, i already have a new ngk, i think i will gap it and get it in today, and just throw the factory one in the toolbox as a spare ... thanks for the advice
02-28-2016, 11:58 AM | #15 |
The spark plug gap should be perfect, right out of the box. Nevertheless, it is good practice to check the gap before installing the plug.
