Closed Thread
Old 11-18-2015, 01:48 PM   #1
Confirmed Compatible Parts: Zongshen RX3
This thread contains a list of parts from other motorcycles which have been confirmed to fit the Zongshen RX3. This is a closed list. Please contribute your discovery of any parts which fit the Zongshen RX3 in the following thread.
http://www.chinariders.net/showthread.php?t=15528
Brake Pads
Front Brake Pads: EBC FA185
If you click the following link, you will download the EBC catalog.
http://ebcbrakes.com/Assets/ecatalog...Cat.html#p=282
On page 282 you will find the FA185 brake pads. This page lists all the different motorcycles which employ these brake pads. Buy sintered, front brake pads for any of these motorcycles, and they will fit the front brake caliper of your Zongshen RX3.
Rear Brake Pads: EBC FA140, EBC FA496
The RX3 motorcycles imported to the United States by CSC have the latest, rear brake caliper. The U.S. bikes use the EBC FA140, EBC FA496 brake pads employed by the following Japanese motorcycles.
Honda CB500X, NC700X
Triumph Tiger 800
Honda CBR250R, CBR300R, CB300F, CBR650F
Suzuki GW250, SFV650
Clutch Parts
Here is a list of the Honda motorcycles which employ the same clutch fiber plates, and clutch springs as the Zongshen RX3.
Honda XR650L
Honda XR600R
Honda NX650
Honda CR500R
Honda CR480R
Honda CR250R
It is reported the Honda, clutch metal plates are too thick.
Shift Lever
The Honda XR650L shift lever is slightly longer than the RX3 shift lever. However, this Honda shift lever, and the many aftermarket shift levers for the Honda XR650L, have a folding tip. The folding tip prevents damage to the shift lever and the engine, should you drop the motorcycle on its left side.
Rear Sprocket
The JTR473 sprocket is identical to the Zongshen RX3 sprocket for bikes with the rear cushion drive.
http://www.jtsprockets.com/catalogue/sprocket/JTR473-40
This sprocket is available with 40T, and 37T.
Old 11-18-2015, 02:25 PM   #2
Spark Plug
The stock spark plug is a Denso U22ESR-N. Denso spark plugs are somewhat hard to find in the United States. Here is a list of other, equivalent spark plugs.
NGK CR7E : Gap 0.031 inches (0.08 mm)
Champion RG96C
Old 11-19-2015, 02:52 AM   #3
Electrical Connectors
Auxiliary Power Plug: Sumitomo, HTW 110 connectors (2-Pin)
Headlight Connector: Furukawa, RFW 090 connectors (6-Pin)
ECU Diagnostic Port: Furukawa, RFW 090 connectors (6-Pin)
Old 12-09-2015, 10:05 AM   #4
Throttle Position Sensor (TPS)
Delphi SS10459
UPC: 689604104682
5S5008 - AirTex/Wells
SS10459 - Delphi
Old 12-19-2015, 07:40 PM   #5
Vapor Canister Purge Valve
The solenoid purge valve for the evaporative emissions canister is the Delphi 1997278, ACDelco 214-641 unit.
http://www.ebay.com/itm/Evaporative-...3D130848197922
Old 12-19-2015, 07:42 PM   #6
MAP/MAT Sensor
The Delphi 28086011, ACDelco 12232201 MAP sensor is equivalent to the MAP/MAT sensor of the Zongshen RX3. Just make sure you get a 4-pin connector (MAT). It's best if the sensor has a sticker which labels the 4 pins: VOut, 5V, MAT, GND.
http://www.ebay.com/sch/sis.html?_nk...p2047675.m4096
Old 12-19-2015, 09:37 PM   #7
The following, radiator fan switch is equivalent to the switch employed by the Zongshen RX3. This switch is designed for the following Suzuki and Kawasaki motorcycles.
Suzuki
GSX-R600 97-05
GSX-R750 96-08
VL/VZ800 01-11
DL1000 V-Strom 03-09
GSX-R1000 01-04
SV1000 03-07
TL1000R/S 98-03
GSX-R1300 “Hayabusa” 99-07
Kawasaki
Ninja ZX-6R 2003-2004
ZX636 2003-2004
ZX600 2003-2004
http://www.ebay.com/sch/i.html?_from...witch&_sacat=0
Old 04-13-2016, 07:52 AM   #8
Rear Hub Bearing Sizes
Rear Hub Bearing, Sprocket Side: 6202 2RS
Rear Hub Bearing, Brake Rotor Side: 6302 2RS
Sprocket Carrier Bearing: 6004 2RS
Front Hub Bearing Sizes
(2) 6302 2RS
Old 03-21-2017, 05:28 AM   #9
I have verified the EBC, MD929D brake rotor is a perfect fit for the front wheel of the Zongshen RX3. This brake rotor fits the following motorcycles.
Front Wheel
98-02, Suzuki Bergman 250
99-02, Suzuki Bergman 400
Old 03-21-2017, 01:20 PM   #10
I have confirmed the brake rotor bolts for the first generation, 2007 Kawasaki KLR650, are a perfect match for the RX3 rotor bolts. Incidentally, these rotor bolts are also employed by the front wheel of my Zongshen ZS200GY-2.
https://www.rockymountainatvmc.com/p...olt-Kit?v=5617
Closed Thread
