Old 11-14-2015, 03:15 PM   #1
Danimal   Danimal is offline
Banned
Doubletake Adventure style mirrors
Did a few things to the RX today preparing for a ride tomorrow.
The 35w bulb CSC sent to replace the stock bulb (low beam blew) was feeble. So I installed a Sylvania Ultra 55/60W H4.
Used a Dremel cut off wheel to make a series of gill cuts on the rear bottom to hopefully help with whatever additional heat is created.
Removed the stock mirrors (my left mirror was always loose) and installed the Ram balls on the bottom. No flats for a wrench, so used a dab of blue loctite and narrow vice grips to tighten.
Then the 6" Ram arms and the mirrors
Folded in for woods riding
And removed the stupid Speed decals. MUCH better
Also got a SAE to lighter plug adaptor so now my portable compressor is in the RX tool mix. Along with tire irons, patch kit and two spare tubes I think that's covered.
Supposed to be sunny and 60 tomorrow. Oh boy!
Old 11-14-2015, 06:01 PM   #2
I see you bought the 'coffin' mirrors, instead of the round mirrors. They look great. Thanks for posting the nice photos.
Can you share a link for the lighter plug/SAE adapter?
P.S. Send some of that heat up to Idaho.
Old 11-14-2015, 07:52 PM   #3
I like those mirrors. Do you have a link?
Strange that they don't have flats for a wrench.
Old 11-14-2015, 08:06 PM   #4
Banned
Best deal is right here
https://www.rockymountainatvmc.com/p...FVU2aQodAb0BgQ
The balls are made by Ram. They're known for not having a flat.
Old 11-14-2015, 08:14 PM   #5
Banned
Here ya go potatoe
http://www.ebay.com/ulk/itm/161088294802
Old 11-14-2015, 08:44 PM   #6
Thanks for posting the link. Rocky Mountain ATV/MC has the best prices on many products. I love shopping there.
Old 11-14-2015, 09:03 PM   #7
Thanks for the link.
Dan Quayle got in trouble for spelling potato with an extra 'e,' but that is the way I was taught to spell many years ago.
Potatoe is an older, but still correct spelling of the word more commonly spelled potato.
http://www.urbandictionary.com/define.php?term=potatoe
Even Wikipedia acknowledges this fact.
The spelling of potatoe, while not terribly common, existed for almost the entire 20th century. For example, the New York Times was still occasionally spelling potato with an –e in 1988. In fact, one can easily find spellings of potatoe all the way up to 15 June of 1992, at which point they suddenly drop off or become used in an ironic way, referencing this incident.
http://blog.oxforddictionaries.com/2...a-hot-potatoe/
Old 11-14-2015, 11:47 PM   #8
AZRider   AZRider is offline
From personal experience, I would suggest that you add an SAE directly to your battery or at least fuse it to the requirements of your compressor. The lighter plug only has a 5 amp fuse and most compressors will blow that in a couple of seconds. I also use the SAE on the battery to attach a battery tender.
George
2016 CanAm Spyder F3-L
Old 11-15-2015, 10:20 AM   #9
Longboarder1968   Longboarder1968 is offline
Tools
Having to buy a new tool set here in Colombia, hoping everything on the bike is metric? Do I need torx set? Trying to keep it basic, combo box/open end wrench set(metric), Allen set(metric), screwdrivers, vice and slip joint pliers, side cutters, need a small socket set(metric) and tire repair kit w/extra tubes& wrench (size?) for axles. Any other suggestions? Thanks! 🇨🇴
Old 11-15-2015, 01:44 PM   #10
No, you don't need a torx set. The rear axle uses 18 mm and 19 mm bolts. I think the front axle uses a 17 mm bolt. However, you can use an adjustable crescent wrench to remove the axle nuts.
