Old 10-07-2015, 06:55 PM   #1
Lee R   Lee R is offline
Lee R's Avatar
Headlight design change?
I noticed my RX3 that just arrived has a different front headlight. No blu-ish tint circle in the bottom.
CSC website:
Old 10-07-2015, 07:02 PM   #2
Riceburner   Riceburner is offline
Riceburner's Avatar
Location: Tigbauan, Iloilo City, Panay Island, Philippines
Is that a "functioning" parking or running light? OH, wait, you don't have the LED running lights along the side of your headlight.... big change.
Riceburner
Robin / Face Hunter I
Medical Mission Matters
www.medicalmissionmatters.org
Old 10-07-2015, 07:03 PM   #3
ElectricCircus   ElectricCircus is offline
ElectricCircus's Avatar
Yes, it's different... seems to be a 5W parking light.
Also lacks the 5-LED stripes at both sides of the reflector.
______________
- ex Honda MB100 (1981)
- ex Honda Nighthawk 250 (1991)
- ex Honda Storm 125 (2009)
- ex Corven Triax 250 Touring (2016) (Zongshen RX3 carb)
Benelli TRK 502 (2018)
Old 10-07-2015, 08:48 PM   #4
Thanks for posting the excellent photos, and letting us know about the headlight change, Lee.
I like your headlight better than the original. I think the new reflector might cast a better beam without the blue dome in the bottom.
Old 10-08-2015, 12:29 AM   #5
detours   detours is offline
detours's Avatar
Did it come with a 35 watt lamp? Fingers crossed it's a 55 watt.
Red 5 standing by!
2014 Ural Patrol
Old 10-08-2015, 02:01 AM   #6
I think I can read 'HS1' at the 9 o'clock position on the base of the bulb. I'm sure its a 35W bulb, since the headlight has a plastic reflector. I wish Zongshen would build the headlight with a metal reflector.
Old 10-08-2015, 11:33 AM   #7
Lee R's Avatar
The bulbs the same 35w from the original. I'll get some shots of the throw tonight.
Old 10-08-2015, 12:28 PM   #8
The RX3 headlight casts a nice beam. However, the stock, 35W HS1 bulb is anemic. I highly recommend you switch to a standard, 55W/60 H4 bulb. It will do a much better job illuminating the road ahead. However, to prevent possible heat damage to the reflector from the hotter bulb, I do recommend you make a hole in the rear of the headlight assembly, as shown in the thread linked below.
http://www.chinariders.net/showthread.php?t=14665
Old 10-08-2015, 01:17 PM   #9
Co2   Co2 is offline
I hesitated to write for lamp type, because different and i thin more sensitive electirical because RX3 injection system, if any voltage accident=much expensive damaged.
İm use my (Sm/dirtbike carb vers.)Philips xtreme vision H4 60/55w , very nice performance.
Old 10-09-2015, 12:21 AM   #10
Danimal   Danimal is offline
Banned
discussed Lee's different headlight with CSC today. Seeing as my bike shipped only two days after his and mine had the earlier headlight. So I asked why
Seems the Canada bike required the new design to meet their regulations.
CSC has decided to simplify by changing over on US as well.
Old 10-09-2015, 12:42 AM   #11
I had not seen the new headlight before now. That is very interesting information; thanks for sharing it with us.
Old 10-09-2015, 12:48 AM   #12
rtking   rtking is offline
Agreed with Spud - thanks for sharing!
For those of us that like the original headlight, I wonder if we should order a spare now?
Of course, I'd like to see if there's a beam pattern difference between the headlights. If the newer headlight offers a broader beam pattern, I might make the switch (but I like the LEDs of the original!)
Old 10-09-2015, 01:50 AM   #13
You make a good point, RT. If a headlight filament is burnt out at dusk, the LED panels still continue to make the bike visible to other motorists.
Old 10-09-2015, 12:15 PM   #14
Not surprised. Transport Canada is very strict.
Old 10-09-2015, 02:01 PM   #15
Lee R's Avatar
I rode the bike last night but didn't get any pictures. I can still say the 35w bulb is inadequate and I'll be switching to a 55/60w bulb. The pattern was good esp the high beam just not enough light. Honestly it's a bit dangerous up here with all the deer to not have adequate lighting.
I'll get some shots of the throw once the rain leaves here in Upstate NY.
