10-05-2015, 11:37 PM | #1 |
Hawk 250 Data
Been helping a friend assemble one (Assembly Pictures - whenever it gets done)
If you consider it a combination of: Honda NX 150 (Engine [maybe] and Some electrical layout - Battery on right side) Honda NXR 150 ESD (2009) (Frame, Plastics, Attachments, Front Disk, Rear Drum, non-applicable ECM controlled engine - Battery on left side as on Hawk) Then some torque values are: Front axle is 44 Nm Top bolt of of front shock clamp 22 Nm (NXR 150 has side-bolt clamp, Hawk has front-bolt clamp) Bottom two bolts of front shock clamp 32 Nm Swing arm is 88 Nm Mono shock is 44 Nm top and bottom Rear axle is 93 Nm Handlebar Clamps 26 Nm (dot on clamps pointing at front wheel) Front disk brake caliper 30 Nm Hope this helps. |
10-05-2015, 11:55 PM | #2 | |
10-06-2015, 04:23 PM | #3 |
Thanks for posting the torque specifications.
10-07-2015, 11:01 PM | #4 |
Hawk 250 Data again
Front muffler mounting bolt 26 Nm
Rear muffler mounting bolt/nut 26 Nm Muffler clamp bolt (exhaust bolts to Cylinder head) 18 Nm Screws the front muffler protector 14 Nm Side stand nut 39 Nm Luggage/Handhold Handles 35 Nm Valve adjustment jam nut 14 Nm (now that's obsessive) Front and top engine mount bolts 35 Nm Bottom and rear (larger) engine mount bolts 60 Nm Multi-bolt engine mount plates 35 Nm I think, but am not sure,since I haven't changed one yet, that front sprocket bolts are 12 Nm. |
10-30-2015, 10:59 PM | #5 |
Carb Jets
I used these from aliexpress.com. Each link gets 12 main and/or 12 pilot. It took a week or so for the shipping (west coast).
http://www.aliexpress.com/item/Mikun...243535818.html http://www.aliexpress.com/item/Modif...243554212.html You put the sizes you want in the comments field when you check out. Or individual jets here: http://www.ebay.com/itm/351533316140...%3AMEBIDX%3AIT http://www.ebay.com/itm/281814107323...%3AMEBIDX%3AIT You can get front sprockets here: http://www.ebay.com/itm/221723164918 As well as ordering the JTF259.17 for the front. Note that the front sprocket that came off the Hawk has a 17.5 mm diameter to the keys and a 20 mm diameter for the shaft. The JTF259.17 has a 18 mm diameter to the keys and a 20 mm diameter for the shaft. Both seem to work fine. |
10-30-2015, 11:01 PM | #6 |
After reading the owners manual...
63 Nm for the front axle. |
10-30-2015, 11:04 PM | #7 |
Speedometer
Unless this HAWK is unique...
The HAWK 250 seems to have gearing for KPH not MPH. Odometer appears to clocking at KMs and seems to be set for 17" front tire not 21" front tire. |
10-31-2015, 05:33 PM | #8 |
I've noticed the same thing it's definitely showing more miles than its gone but I don't know about the speedometer I think mine is broken it seems to not read properly above 20mph.
10-31-2015, 08:00 PM | #9 | |
Go for a ride in a 30MPH zone, and see if it points to something higher, like 50. If you have GPS, use that for comparison. Most smart phones will utilize free speedometer apps, and they can usually be converted from MPH to KM/H.
11-15-2015, 02:17 PM | #10 | |
http://www.ebay.com/itm/371437493889...%3AMEBIDX%3AIT However, because the bolt head is on the top rather than the bottom the install requires you to take the front sprocket cover plate off to install. Not a big deal just two 8mm bolts. The various aluminum (multi-colored) shifters on ebay also work, but are about 3/4" shorter.Albeit color coordinating with the bike. Look for ones with the 155 mm reach. The shifter shaft spline is 11mm. |
11-18-2015, 01:08 AM | #11 |
I clocked my hawk with my sportbike and the mph was 5 over what it was saying on the speedometer. This clocked at 35mph. Ive had the hawk up to 65mph on the speedometer.
11-18-2015, 07:18 AM | #12 |
If it's 5 over at 35, it will be 10 over at 70...might want to keep that in mind...about 14% off, same as the Cyclone RX-3
11-21-2015, 02:33 AM | #13 |
Alternate Toolbox
Didn't like the tools hidden under the seat... so..
http://www.harborfreight.com/welding...per-46477.html 4 dollars on sale and some spray paint leads to a subtle tool box. It is much more subtle that the photos imply. Attachment is made to already existing mounting brackets. Standard metal banding material was cut, drilled, and bent around container for mounting bands. M6-1.00 pan head bolts for attachments. Watertight to boot. If it were done in silver it would just about match the plastic covering the muffler. |
11-21-2015, 04:12 AM | #14 |
Very cool. Looks like it needs a shotgun sticking out of it.
11-21-2015, 11:15 AM | #15 |
Genius! Now THIS is a perfect example of what being a China Rider is all about! An awesome tool kit for 4.00. Brilliant.....
