08-17-2015, 11:49 PM | #1 |
Starting trouble
Hello I have a Kease Skyhawk 250 that will sorta start. Ok here goes full choke I try to give it gas and in a spot it try's to start but other then that it will not. Has new carbs and coils and wires plugs and cdi. Any one think of something I missed ?
Thanks. |
08-18-2015, 01:23 AM | #2 |
Is this a used new to you bike? If not how this happen?
08-18-2015, 05:34 AM | #3 |
Is the CDI right type (250 twin needs the 1.5uf capacitor model | Generic chonda thumper = 1uf cap )? Source coil's voltage output within limit (old chinese bike often F***ed, so there's "DC-cdi" <some thingy that turns 12v to AC 200v > for quick fix )? Carb's type ? http://chinariders.net/showthread.php?t=14439&page=3 | Trigger gap (~0.5mm) ...
08-18-2015, 08:08 AM | #4 |
No its not a new atv I bought it not working cheap, I went to A J parts who sells Kasea parts and bought a new cdi from them. So it should be right. I will call them and ask them today I would of never thought of that THANK YOU.
08-21-2015, 06:51 AM | #5 |
I have found many times that even though the plug will fire out side the cylinder, it does not work inside. I have found that several times that just changing the plugs on my kids 110cc tao tao have made it run well.. not sure of more, just is that.
08-21-2015, 08:11 AM | #6 |
you dont neccisarily need to choke it... have you tried without the choke? idont ever need the choke on my 200cc shinray dualsport....
08-21-2015, 09:05 AM | #7 |
I have tried with and with out the choke.
08-21-2015, 11:17 AM | #8 |
Are you getting a strong spark?
08-21-2015, 12:06 PM | #9 |
Right now I'm making sure the battery is fully charge this week end I will try some thing's and let you know thanks
08-23-2015, 03:15 AM | #10 |
Ok this is what happen I used starting fluid first with the choke open would not start. So I put some fluid with the choke closed and using the throttle and it started up but I had to keep the choke closed and it would not idle at all by its self had to use the throttle. So any one know some thing I don't know ?
thanks |
08-23-2015, 03:51 AM | #11 |
Tuned the carb?
These chonda twin was popular at pre "gashol" days in it's motherland, Dealer may receive the wrong shipment. So i always ask what's the type of those carb -Keihin / Mikuni? -Slide / CV ? -Real / Copies ?
08-23-2015, 12:51 PM | #12 |
They are Keihin brand new ones same ones that where on it when I bought it. I bought them from A&J parts they get them from SMC the maker of the atv . All the parts are from them oh I did get a new kill switch to . How many turns on the carbs out after setting the screw out?
Thanks |
08-23-2015, 04:31 PM | #13 |
2 & quarter
Quoted from Japanese material https://drive.google.com/open?id=0B2...zU5OEw0YV9GZTQ --- Exploded view of VE26... : http://www.impex-jp.com/assets/image...048_E-15-1.png http://www.impex-jp.com/assets/image...049_E-15-1.png http://www.impex-jp.com/assets/image...050_E-15-1.png http://www.impex-jp.com/assets/image...051_E-15-1.png
08-23-2015, 09:47 PM | #14 |
Sorry buy what is that cant read it?
08-23-2015, 10:53 PM | #15 |
That pdf is stolen from a Honda authorized shop
It's quite easy to figure out 90s twin carb (from H to T) http://www.h6.dion.ne.jp/~nori-to/re...l_database.htm Rebel = (Year) H? | (Engine type) MC06E | (Carb info is in the right side) Needle | Float level | Pilot Air | other useful info for this is engine is oil capacity (in liter) / rpm / spark plug BTW Katakana isn't that hard --- Parts in English http://www.boltonmotorcycles.com ('95 CA250)
