Old 06-27-2015, 02:30 PM   #1
Firefighter18256   Firefighter18256 is offline
Clutch Help
I have a Sunl sla 110cc. My clutch is slipping how would i go about adjusting it and what is the location of it
Old 06-27-2015, 06:41 PM   #2
Adjuster's Avatar
Is the clutch manual, semi auto or fully auto?
Old 06-27-2015, 07:40 PM   #3
manual
Old 06-27-2015, 08:41 PM   #4
Adjuster's Avatar
Do you think its an issue with the clutch not engaging needing a cable adjustment or replacement or are the clutch plates worn and slipping?
Old 06-27-2015, 09:51 PM   #5
gears are slipping, now when i hit the throttle it wont go if i hit it a few times then it does
Old 06-27-2015, 10:30 PM   #6
Adjuster's Avatar
You buy the clutch you need as a complete assembly. You also need a special clutch removal tool. Many people make this tool themselves but here it is. Just search YouTube for clutch replacement videos for the Honda horizontal engine. Also called a pit bike engine. A monkey bike engine. Or by cc 50cc, 70cc, 110cc. You do not need to remove the engine from the bike as long as you have access to the clutch cover case.
http://www.ebay.com/itm/CLUTCH-HUB-R...64fcb3&vxp=mtr
http://www.ebay.com/itm/Manual-Clutc...item43dd7aa3ec
Old 06-27-2015, 10:46 PM   #7
Adjuster's Avatar
I would also replace the cable. You need to remove and measure your existing cable and purchase an exact duplicate.
Old 06-27-2015, 10:48 PM   #8
Adjuster's Avatar
Is your bike one of these models?
http://www.powersportsmax.com/index_...hp/tID/1/bID/5
Old 06-30-2015, 02:53 AM   #9
pete   pete is offline
pete's Avatar
theres a plate on the right side of the motor...
clutch push rod ajuster is under it...
check you have free play in the cable/lever...
09 XT660R ...
06 TTR250 ...
80 Montesa H6 125 Enduro...
Current resto projects..
81 Honda CT110...
80 Kawasaki KL250A1...
http://www.remotemoto.com/
E-mail... xtpete1@gmail.com
Old 06-30-2015, 09:48 AM   #10
Patrick4653   Patrick4653 is offline
this site has great parts and a tech department you can call
http://www.outsidedistributing.com/C..._p/11-0109.htm
