Old 05-05-2015, 06:29 PM   #1
Tutorial: How to Change the Headlight Bulb
While I am awaiting the arrival of the upgraded, LED headlight, I removed the stock HS1 bulb, and installed a brighter, H4 bulb in my RX3's headlight. I am very pleased with the light pattern, and the extra illumination the H4 bulb projects on the road ahead.
Here are the steps I followed to change the bulb.
Slightly loosen all the windshield bolts, so you can tilt the windshield slightly for some clearance with the headlight. EDIT: This might not be necessary, if you are willing to wiggle the headlight a little to coax it out from behind the windshield.
Remove the two bolts at the side of the headlight. Note the alignment of the headlight with the bracket; this will affect the elevation of the light beams.
Pull the headlight assembly out from underneath the windshield.
Holding the headlight assembly so it does not fall, disconnect the wiring plug by pressing down on the tab.
Remove the nine bolts from the back of the headlight assembly, and open the headlight assembly.
Remove the plug from the bulb.
Remove the rubber boot surrounding the bulb.
Twist the the bulb retainer counter-clockwise, and remove it.
Remove the HS1 bulb.
Install the H4 bulb. It might be necessary to flatten two small projections on the mounting plate of the bulb to allow the bulb to sit flat against the mounting plate of the headlight.
Repeat all of the above steps in the reverse order to re-install the headlight.
I borrowed the disassembled headlight photograph from Katflap. Thanks, mate.
Old 05-05-2015, 06:32 PM   #2
I have added a link to this tutorial in the Zongshen RX3 (ZS250GY-3) Modifications & Maintenance thread, which is pinned to the top of this forum.
http://www.chinariders.net/showthread.php?t=14228
Old 05-15-2015, 11:49 AM   #3
I know at least one RX3 owner has expressed concern regarding the extra heat generated by the 55W/60 H4 bulb. So far I haven't noticed any problems using the hotter, brighter bulb. However, if one is concerned the extra heat might damage the plastic reflector, he can always drill a few well-placed ventilation holes in the back of the headlight.
The headlights of all my other motorcycles are completely open in the back. Also, as you can see in the photograph, nothing inside the RX3 headlight will be damaged by a little dirt or moisture.
Old 05-15-2015, 11:06 PM   #4
AZRider   AZRider is offline
I'm not a physics major, but wouldn't air movement provide sufficient cooling to prevent overheating? Works for Harleys. Also, it's an incentive to ride, ride, ride.
George
2016 CanAm Spyder F3-L
Old 05-15-2015, 11:13 PM   #5
I agree. Most people don't run the headlight very long when the bike is not moving. Also, the glass area of the headlight is very large, and dissipates a lot of heat. I haven't noticed any problems so far, and I don't think I will encounter any problems. However, if one is concerned, he can easily drill a few ventilation holes in the back of the headlight.
Old 05-19-2015, 05:15 PM   #6
No1Vic   No1Vic is offline
No1Vic's Avatar
Think I'll be following your headlight upgrade route Spudrider with a brighter H4 bulb, I did fit a HID bulb kit but it meant cutting the back of the headlamp housing to get it back together so pulled it out. Glad to see your write up on the LED bulb, I would have tried one but like you need to see more to the sides illuminated not just in front.
2015 Honley RX3
2010 Suzuki 1250 Bandit
2006 Suzuki Hayabusa
Old 05-23-2015, 02:37 PM   #7
katflap   katflap is offline
katflap's Avatar
Getting one of these bulbs from taobao
( feel free to delete post)
Old 05-23-2015, 03:23 PM   #8
Adjuster's Avatar
^^^^I like it^^^^ Looks very Star Trek
Old 05-23-2015, 03:42 PM   #9
Now that is an LED headlight.
Old 05-25-2015, 10:53 AM   #10
That's clearly going to need some protection, or it just won't last.
Old 05-25-2015, 11:46 AM   #11
JTHSPACE   JTHSPACE is offline
JTHSPACE's Avatar
I noticed it's a right hand twist, they are going to need the left hand one for the U.S. otherwise it will dip the wrong way.
Riding bikes for over 40 years
Honda C50 / SS50 / CB125 / CB250
Velocettes (various)
Piaggio's / Honda's / Yamaha's
Raptor . . . . the List Goes On . . . .
Old 08-17-2015, 03:39 AM   #12
detours   detours is offline
detours's Avatar
I was in the auto parts store and saw an H4 Silverstar Ultra on sale ... and remembering Spud's review of the light distribution of the stock headlight vs the LED, I decided to buy one and try it out in the RX3.
I'm aware of the potential heat issues, so I'll keep an eye on the temps.
The swap was easy ... although I don't know why Zonghsen used NINE screws on the headlight assembly! I went for a ride tonight and the difference was amazing ... so much light! And the high beams lit up everything!
Now, I've used Silverstars before and they have a limited life. They're also sensitive to vibration, so I may kill this light early. But if I do, I'll just replace it with a standard H4 halogen. Meanwhile, I won't be afraid to ride the RX3 at night anymore!
Red 5 standing by!
2014 Ural Patrol
Old 08-17-2015, 03:53 AM   #13
Indeed, the stock headlight with an H4 bulb does an excellent job illuminating the road. After switching to the H4 bulb, my RX3 now easily has the best headlight of all my motorcycles.
After riding almost 7,500 miles, I have noticed some potential discoloration of the headlight reflector. Therefore, I cut a hole in the back of the RX3 headlight assembly so it is large enough for me to change the light bulb without having to remove the rear cover. I also placed a small hole at the bottom of the headlight assembly to allow for water to escape.
The hole in the headlight assembly also allows heat to escape the headlight easily, helping to prevent any possible damage to the reflector from using a light bulb with higher power.
Old 10-08-2015, 07:15 AM   #14
keithmaine's Avatar
Great tips spudrider
Old 11-24-2015, 02:32 PM   #15
DaytonaMike   DaytonaMike is offline
DaytonaMike's Avatar
How´s it holding up?
Spud I think its been a while since you did this modification. How is it holding up? Any issues? Anything you would do differently? Do you still recommend this mod and the removal of so much of the back housing?
