Old 05-02-2015, 01:45 AM   #1
Curtdawg   Curtdawg is offline
Gy6 150cc short vs long case
I'm lookin for some way to identify which one I have so I can order parts. Is there someway to tell? Maybe just measurements of the case? Also was thinking about Doing a 180 cyl swap. Is there a thread already on it?
Old 05-02-2015, 03:15 AM   #2
humanbeing's Avatar
Short / Long ? http://totalruckus.com/phpBB3/viewto...?f=116&t=40542
Fitting 58.5mm kit http://item.taobao.com/item.htm?id=43470971456 is easy
61 kit (Ø65mm) doesn't direct fit to MOST standard GY6 (125cc Ø61.5mm | 150cc Ø63mm) ,so there's this http://v.youku.com/v_show/id_XMzY3ODM5NzAw.html ( if understands Cantonese)
This http://item.taobao.com/item.htm?id=12300542480 (or higher quality Taiwanese equivalent) is a MUST to squeeze engine's power.
Old 05-02-2015, 01:38 PM   #3
I just did some research on this, so I could buy new gaskets. The answer is in the number of bolt holes on the CVT cover; the short case has 8 holes, and the long case has 10.
Old 05-02-2015, 01:39 PM   #4
I haven't seen a 180 swap on this forum yet, but the case length shouldn't affect it.
Old 06-30-2015, 12:18 PM   #5
Patrick4653   Patrick4653 is offline
Here is a good link to engine types.
http://www.outsidedistributing.com/category_s/2273.htm
