Old 01-24-2015, 05:46 PM   #1
Adjuster's Avatar
Spark Plug Help???
The spark plug that came with my Chinese engine is marked 'A7TC'. I believe this is the standard spark plug that come with all Honda clone scooter engines of similar 125cc size. I want to purchase an NGK iridium equivalent but I am getting conflicting information of if I need a CR6HIX or a CR7HIX and I am also seeing it is offered in resistor and non resistor. Can someone in the know of all worldly spark plug knowledge help me with this? Thanks
Old 01-24-2015, 05:55 PM   #2
Adjuster's Avatar
Ok further research tells me I need NGK CR7HIX but I would still appreciate if anyone can confirm. Thanks
Old 01-24-2015, 07:11 PM   #3
humanbeing's Avatar
http://chinariders.net/showthread.php?t=14251
Denso IUF22 also quite good.
Old 01-24-2015, 07:35 PM   #4
Adjuster's Avatar
Thanks human, I have now learned the difference between the 6 and 7 is heat range. The 7 is the recommended plug for my temperature range here in Florida. The 6 is for colder climates.
Old 01-25-2015, 01:19 PM   #5
Exactly right, and that language applies to other NGK plug sizes as well, including the B and D.
