Old 09-01-2014, 02:57 AM   #1
Zonganaut   Zonganaut is offline
Zonganaut's Avatar
Chain slack for ZS200GY-A?
Just been tightening my chain. Wondered if any of you knew what the recommended slack would be for the ZS200GY-A?
I had a look through the GY-2 service manual and they recommend 15-25mm.
Reckon the same for the GY-A? Or being a hondoid would that make a big difference?
Old 09-01-2014, 03:27 AM   #2
pete   pete is offline
pete's Avatar
How I go about setting the chain testion on my bikes is...
i put a tie down from the axle/swing arm " where you can get it on" to the frame
somewhere above it..compress the suspension till the engine sprocket shaft / swing arm pivot / rear axle are in line... tighten the chain till there 10/15mm play in it... after you have done it a few times yer get to know.. don't need to compress the suspension any more..
with all 3 inline that is the longest point the chain needs to fit...
09 XT660R ...
06 TTR250 ...
80 Montesa H6 125 Enduro...
Current resto projects..
81 Honda CT110...
80 Kawasaki KL250A1...
http://www.remotemoto.com/
E-mail... xtpete1@gmail.com
Old 09-01-2014, 09:20 AM   #3
zingshoen   zingshoen is offline
zingshoen's Avatar
yeah, pete s given you the good oil, my speculated guess would be it is more like 30 to 40 mm as on a small XL.
BTW: the specs for the GY-2 are (1) different and (2) i m not sure they are right, coz they are tight.
1971 Garelli Gulp 50cc with open ports and 16 mm Bing Carbie + 1980 Honda XL 223 ZS + 2007 Zongshen LZX200G + DR400SM
Old 09-01-2014, 11:46 AM   #4
X2 on Pete's guidance.
The alternative is to place the bike on a stand, disconnect the rear shock and move the swingarm up until the two sprockets and the swingarm pivot bolt are in line. Same result.
Pete's tie-down idea is faster.
Old 09-01-2014, 05:04 PM   #5
Zonganaut's Avatar
Thanks for the advice guys. Have loosened it slightly, now have just over 1" slack. Feels much better.
Next task: clean carb!
Old 09-02-2014, 02:51 AM   #6
Zonganaut's Avatar
Stumbled upon this handy tool tip from Rallye Raid:
http://www.rallyeraid.co.za/rear-axle-alignment/
Looks like a goer - less fiddly than trying to eyeball the tape measure anyhow!
Old 09-02-2014, 10:55 AM   #7
That's a very good idea! I need to try that trick on my ATV.
