Old 07-24-2007, 03:36 PM   #1
sr500   sr500 is offline
Strange sound from the rear axle
When i going verry slow and turning, i can hear a PLING from the rear axle. Is this normal? I have a 200cc Quad with Loncin engine, four speed and chain.
Old 07-24-2007, 05:49 PM   #2
NewEnglandTrails   NewEnglandTrails is offline
sr500,
Have you checked the bolts that hold the rear sprocket on? I overlooked tightening these when I put my 200cc atv together and heard some noise and found them very loose after just a couple hours of riding... After some loctite and being vigilant ever since I havent repeated the problem..
Also check your chain tension....
NET
2006 HIBIRD QH200-st atv, 2005 Kinroad 200GY-01, 2006 Roketa DB-05, 1980 Kawasaki KZ440 LTD
Old 07-24-2007, 06:12 PM   #3
katoranger's Avatar
Check to make sure the chain isn't binding or is too loose.
Allen
Old 07-25-2007, 09:37 AM   #4
My rear sprocket came loose to, but i change the bolts to torx, and use loctite. But the sound is still there. I did se, that the svingaxle have a verry loose fit in the front bushings. Nothing wrong with the bushings but the axle has a to small diameter. China high teck. I am going to make a new axle with the right diameter, and se if the noise stop.
