Old 08-13-2014, 05:33 AM   #1
l-ovie   l-ovie is offline
Question 200cc engine identification and info
Hi all
I have just recently bought a second hand 200cc Yamoto, shaft drive atv and I cannot find any info on it. From what I can gather it seems to be a 200cc loncin (or copy of) OHC??...see attached pic....what do you think?
I want to ensure everything is ok and up to spec, for example valve clearance? I have come across what seem to be conflicting specs (or me with wrong engine identifcation), .002" for both or .003" inlet and .004" exhaust.
Does anyone know where I can get service manual or similar??
Your help is much appreciated!!!
Old 08-13-2014, 06:21 AM   #2
humanbeing's Avatar
What's stamped ( ??1??FM? /http://www.motorfans.com.cn/bbs/t_17705986.htm) on the engine?
Commonest "CB" (OHC) 200 had a 63.5 bore. Manual : http://chinariders.net/showthread.php?t=13912 | Honda spec about these 63.5 x 62.2 = IN/EX 0.1mm
Old 08-13-2014, 07:06 AM   #3
it is stamped 163FML with engine number directly below
Thanks for the quick reply!!!
Old 02-16-2015, 12:13 PM   #4
wilphins1   wilphins1 is offline
Head Scratching 2005 komodo
I have the 2005 komodo shaft drive and im needing the gear box for this same motor.Any idea where i can find parts for the drive?thanks
Old 04-23-2015, 08:13 AM   #5
Ben28   Ben28 is offline
Hi, Are you still looking for the manual? I've just rebuild an old 200cc ATV same as your stamp, I think it might refer to Fuxin Manufacturing Limited, they make engines. The Clymer manual for 1980 Honda's 125-200 is the engine you want to take your spec from. I did and my engine is humming. I'm only passing on what I found to be good advice. There's going to be some differences but if you're any way handy you'll figure that out. Valve clearances etc are all there. I have a copy and can email you it if you want.
